UK-POLOS.NET - THE VW Polo Forum • 6n2 rear weel abs sensor replacement
Posted: Tue May 13, 2014 8:52 am
by sjpope78
As above has mine scanned and it has come up sayin both rear wheel sensors faulty, the mechanic that scanned it ( owns the garage family friend) says he doesnt think that they would both be faulty its prob a wiring issue, which i know is under the rear bench, for the price of the sensors £7 each is it worth trying that 1st?? If so are they a b***h to get out ive heard they can be?
cheers for and help gys
Simon
Re: 6n2 rear weel abs sensor replacement
Posted: Tue May 13, 2014 9:04 am
by alexperkins
Its unlikely they are both faulty together. Check the connections under the rear bench, then check the connections at the wheels
They are pretty difficult to get out - normally the bolts snap and have to be drilled out. If you do remove it, you need to use a good penetrating spray on the bolts that hold the sensors in first to loosen it up.
Posted: Tue May 13, 2014 12:41 pm
by sjpope78
Once ive got the rear bench up there is the black cover with wires coming out, what wires are for the abs sensors??
Posted: Tue May 13, 2014 12:43 pm
by alexperkins
Theres a wire that goes left and a wire that goes right - both have connector plugs on them, and go through rubber grommits. These are the ABS wires.
Posted: Tue May 13, 2014 12:47 pm
by sjpope78
ok thanks and these will be found once i unscrew the black cover? , as i have noticed wires that run near the seat belt clips that have black conectors also, what are these??
Posted: Tue May 13, 2014 1:08 pm
by alexperkins
No, the black cover is for the fuel pump
Take a picture and ill point out which is which
Posted: Tue May 13, 2014 1:12 pm
by sjpope78
ok leave it with me, once ive taken the pic ill pm you it
