12v power socket in boot
Posted: Sat May 24, 2014 3:24 pm
by BlackSEL
I have a 2011 SEL without a 12v socket in the boot and looking to fit one.
I have read that in the mark 5 golf there was a cable run to the boot for the socket even if it wasn't fitted. Does anyone know if this is the case with the Polo? :?
Tom
Re: 12v power socket in boot
Posted: Mon May 26, 2014 7:50 am
by BlackSEL
Has anyone fitted a 12v socket in the boot? :)
Posted: Mon May 26, 2014 1:55 pm
by greypolo9n3
ive got a tdi se and i have a 12v in the boot from factory..
weird this how they leave these sort of things on different cars
Posted: Mon May 26, 2014 6:16 pm
by BlackSEL
greypolo9n3 wrote:ive got a tdi se and i have a 12v in the boot from factory..
Yeah, my wife has a 9n3 with it in.
Posted: Mon May 26, 2014 6:54 pm
by Mart!n-GTI-DK
The BlueGT dosen't have it either...
I have thought about installing one or two in mine just in case I need one at some point for a cooler or something. :)
Posted: Mon Jun 02, 2014 10:06 pm
by dl27
I'm busy with that retrofit at the moment - hopefully will get to it next weekend if something else doesn't crop up. Required parts are really cheap. Will let you know how it went!
Let me know if you need the part numbers.
Damir
Posted: Mon Jun 02, 2014 11:57 pm
by BlackSEL
dl27 wrote:I'm busy with that retrofit at the moment - hopefully will get to it next weekend if something else doesn't crop up. Required parts are really cheap. Will let you know how it went!
Damir
Part numbers would be great :D Can you take some pics as you go please :wink:
Posted: Tue Jun 03, 2014 7:27 am
by dl27
The part numbers I have are:
1K0 919 021 - 12V socket
000 979 145E - Wiring set, you'll need 2 of these
191 919 321 - 3 pin male plug housing (white)
1K0 919 341 J 9B9 - socket cover, non-illuminated, black
These are the absolute minimum you need which will require you to cut into the existing wiring for the cigarette lighter (or front 12V socket). I chose a slightly more elegant route by getting 2 female counterparts to the male plug housing and 1 extra male plug with appropriate wiring to be able to do the job without cutting any of the car's existing wiring.
You could also use an illuminated socket cover, but I don't see much benefit from that. If you'd like the part numbers for the female housing and the wiring, let me know - I'll need to look at ETKA when I get a chance.
Posted: Wed Jun 18, 2014 9:24 pm
by BlackSEL
dl27 wrote:The part numbers I have are:
Thanks for the info, going to get the bits ordered :D
Posted: Thu Jun 19, 2014 8:12 pm
by ciclo
