How can i connect new rear speakers?
Posted: Tue Jun 29, 2004 4:49 pm
by Flipi
Hi, i´ve a beta radio with 4 speakers but all of them in the front, so i´ve decided to upgrade my radio with two rear speakers, the problem... volkswagen service, charges me around 500€, I want to put it myself but i don´t know how i must connect the speakers because my radio only have two channels, so my question is: make the connection in serial or in parallel with the front speakers. Thanks... greetings from Spain.
Posted: Tue Jun 29, 2004 6:11 pm
by logistix
in my dad's transporter we have a similar setup: front speakers are connected to "right" channel and rear speakers are connected to "left" channel. this way the stereo output is messed up a little but you can use left-right balance as a fader (as a front-rear balance).
hope this helps!
Posted: Tue Jun 29, 2004 6:26 pm
by logistix
by the way, connection is in parallel of course
Posted: Wed Jun 30, 2004 12:16 am
by david burton
I might have to question that - I've always been told to wire the speakers in series - this is because the radio sees twice the resistance rather than half (in parallel).
You are more likely to damage the headunit and speakers by giving it too low resistance - hence why good amps are rated at 2 ohms stable, and average ones are 4 ohm stable.
however, I think the standard vw tweeter / woofer setup is in parallel?!
go figure!
