UK-POLOS.NET - THE VW Polo Forum • Coilovers making clunking sound?
Posted: Sun Nov 09, 2014 7:53 pm
by jagjot
I have vw polo 1.6 16v gti, MKV, year 2000.
I recently changed my shocks to FK coilovers. bought from ebay - seconds. For some reason when I turn steering right or left it makes clunking sound.
http://www.ebay.co.uk/itm/161467177144? ... EBIDX%3AIT
Sounds like springs from front coilovers. I also notices top of springs have no rubbers its just aluminium plate and the springs. thins might be the problem??
any ideas?
Re: Coilovers making clunking sound?
Posted: Mon Nov 10, 2014 9:06 am
by jagjot
Looks like I am missing the top noise prevention cushion. I will grease the cushions and buy the top cushion.
Check the following links. if you are stuck or have the same issue. Must read...
http://www.meganracing.com/tech/faqs.as ... ubject=CDK
http://www.clublexus.com/forums/suspens ... clunk.html
This is what I need. The top cushion...
Posted: Tue Nov 11, 2014 8:16 am
by jagjot
Apparently it was none of the above. It was strut bearings. Now I am changing the bearings over the weekend.
Any one know which are the best bearings?
Posted: Tue Nov 11, 2014 8:24 am
by jagjot
Another issue I cannot use my old strut bearings. FK coil over are not wide (diameter wise).
So, I need to get the fK ones.
Posted: Tue Nov 11, 2014 9:06 am
by alexperkins
Ive never seen coilover that need a specific top mount. Normally they come with a plate that allows them to fit the factory mount
Posted: Thu Nov 13, 2014 12:30 pm
by jagjot
You are right.
I called FK supplier and he said it sound like my top struts bearings. I will try changing it over the weekend..
Thank you...
Posted: Sat Nov 22, 2014 8:22 pm
by jagjot
Guess what guys. I managed to open the coil overs and there are no bearings in the strut.. I bough them new from vw dealership in £37 for 2. requesting money for bearings back from the ebay seller. hoping it will get resolved in a positive fashion.
Posted: Wed Apr 13, 2016 11:08 pm
by Gridz1
jagjot wrote:Another issue I cannot use my old strut bearings. FK coil over are not wide (diameter wise).
Alright mate. I have the same problem did you manage to sort this out? If you did how did you do it?
