UK-POLOS.NET - THE VW Polo Forum • BASIC MK4 BUYING GUIDE
Page 1 of 2
Posted: Sat Jul 03, 2004 7:54 pm
by pettsy
I made this up for a mate when he went to look at a mk4 polo, thought i'd share it on here 8)
Feel free to make it a sticky etc
MK4 POLO - BUYING GUIDE
AREAS OF RUST
- Under the rubbers that cover the holes in the doors, where the hinge goes in
- At the very end of the rubber strips on the roof, where the roof meets the boot lid
- Behind the plastic mirror bases (normally invisible)
- rust in wheel arch-can catch behind rear wheel
THINGS TO CHECK
- electric windows always play up
- always look for records of regular oil changes on these-they need it
- Pedal Box! Same fault as Caddy's etc. Clutch goes stiff, doesn't get changed in time, puts strain on Cable and twists/breaks/cracks pedal box mounting bracket that's bolted to the bulkhead.
- Cambelt changed between 40-60K
- Electric mirror heaters pack up: £36 for the glass!
- Check inside the boot under the carpet for a factory sticker with option codes and engne code. If this is missing, car has been rear-ended
- leaky heater matrix
- iratic speedo
- Power steering pump
- Faulty temperature sensor
- Wiring loom into front doors breaks (bare wires touching each other )
- Cracking paint in join under rear lights
- Rear Bulbs blowing regularly
- Gearbox bearing
- Brake Discs Warping
- Squeeky Rear Drums
- They Go through Wheel Bearings like they're going out of fashion (with Larger Alloys on)
- Swolen Crank Breather Pipe
Posted: Sat Jul 03, 2004 8:03 pm
by carmadaaron
thats a cool guide u got there.
i had throttle body problems for over a year. apart from that it was pretty flawless.
Posted: Sun Jul 04, 2004 1:21 am
by chubbster
holy moly, im scared now! havent seen any of that yet!
Posted: Sun Jul 11, 2004 11:26 am
by pettsy
can someone make this a sticky?
Posted: Sat Jul 17, 2004 9:36 pm
by pettsy
Hello? Any Mods?
Posted: Mon Jul 19, 2004 8:39 am
by KarlM
Apologies Petts, have been on a large one all weekend in Sheff - not been on net since Friday morning.
All sorted now and cheers for the write up :)
Posted: Thu Jul 22, 2004 5:54 pm
by Fjo
Good Guide... i've had the gearbox bearing go which lead to a rebuilt for the box, noisy back drums- yep, back bulbs go a lot, but (touch wood) never a wheel bearing n im carryin 15's
Gearbox bearing???
Posted: Thu Oct 14, 2004 11:14 pm
by martin9aj
Hey,
anyone know What are the symptoms of the gearbox bearing going?
cheers
Posted: Thu Oct 14, 2004 11:21 pm
by david burton
i think the gearbox will be commonly noisy with the clutch pedal up, but when down the noise goes - this is the front bearing
clutch release bearing is wearing if it's noisy when the pedal begins to be pressed, and another bearing is at fault if it's noisy when it begins to bite (can't remember the name).
my old car was noisy when cold and pedal fully up. checking the levels might be a good idea.
Posted: Mon Jan 03, 2005 4:03 am
by Tahrey1043
may be looking at a 1.4 (16v?) 5 door tomorrow, will be printing that list to take with me!
any tips perculiar to the valvers? :)
and what might cause a 1.6 to cut, heading towards junctions? (granted, it was cold, but not something you expect too much even on a knackered mk3)
Posted: Sat May 21, 2005 5:08 pm
by DScape
Hey, just want to say thanks for the guide! Just recently bought a Polo and took the guide with me 8)
Posted: Sun May 22, 2005 7:32 pm
by Speedlaw
You're welcome. If anyone has any additions to the list, feel free to add them.
Good luck with your new car!
Posted: Wed Jan 11, 2006 10:24 am
by Mint
Mines missing, what are other symptoms of a rear-ender? Im positive it's not been rear-ended but now im in doubt.
Posted: Sun Jan 22, 2006 6:54 pm
by pettsy
Sometimes they are just missing for no apparent reason,so don't worry yourself too much (i have bought mint cars with no stickers there)
Obvious signs of rear ender would be noticeable underneath the car, no,or different looking underseal, paint overspray on the inside of the panels etc
Hope that helps,Pettsy
Posted: Tue Mar 28, 2006 7:25 pm
by psibob84
Cheers for this list
I actually just found this forum and am coincidentally going to pickup a mk4 on saturday so i will definately print this and take it with me
