POLO 6R. HEATED SEATS. OEM.
"This information will be continually updated"
Current flow diagrams
Onboard supply control unit, Heated front seats control unit
Image Image Image Image
J519 - Onboard supply control unit
J774 - Heated front seats control unit
SB37 - Fuse 37 on fuse holder
T16n - 16-pin connector
T73a - 73-pin connector
T73b - 73-pin connector
96 - Earth connection 1, in seat heating wiring harness
199 - Earth connection 3, in dash panel wiring harness
606 - Earth point, under the centre console near gear stick
A4 - Positive connection (58b), in dash panel wiring harness
A21 - Connection (86s), in dash panel wiring harness
A141 - Positive connection 2 (58b), in dash panel wiring harness
Heated driver seat regulator, Heated front seats control unit, Heated seat cushion for driver seat, Heated backrest for driver seat
Image Image Image
E94 - Heated driver seat regulator
L44 - Seat heating switch illumination bulb
T2eg - 2-pin connector
T2eh - 2-pin connector
T6ac - 6-pin connector
Z6 - Heated seat cushion for driver seat
Z7 - Heated backrest for driver seat
110 - Earth connection 2, in dash panel wiring harness
238 - Earth connection 1, in interior wiring harness
439 - Earth connection 3, in dash panel wiring harness
605 - Earth point, on top end of steering column
Heated front passenger seat regulator, Heated front seats control unit, Heated seat cushion for front passenger seat, Heated backrest for front passenger seat
Image Image
E95 - Heated front passenger seat regulator
T2ei - 2-pin connector
T2ej - 2-pin connector
T6ad - 6-pin connector
Z8 - Heated seat cushion for front passenger seat
Z9 - Heated backrest for front passenger seat
Info
It is advisable to read the whole topic but in this link you will find very good information.
http://www.uk-polos.net/viewtopic.php?f ... 11#p520897
Notes
Removing and installing front seat (cushion cover and padding, backrest cover and padding)
Disconnect vehicle battery
WARNING
Electrostatic discharges may result in unintentional triggering of airbag. Therefore, the mechanic must electrostatically discharge him/herself before disconnecting the igniter and earth wires. This can be done by briefly touching the body or striker plate of the door.
Image Image Image
cushion, backrest
WARNING
If the front passenger seat cushion padding is renewed, the seat occupied sensor, front passenger side -G128- must also always be renewed
Notes
In the seat padding in vehicles with a seat heater is renewed, the heating element is also to be renewed.
Assure a dust free adhesive area on the padding.
Bond heater element fold-free to padding.
Links to buy
Cable set http://www.kufatec.de/shop/en/volkswage ... t-ibiza-6j
Note: It is necessary to consider whether the onboard power supply control part can encode on seats
peter_dk25
Drives: Blue GT
Re: POLO 6R. HEATED SEATS. OEM. (under construction)
Post by peter_dk25 »
:D
It is not for me peter_dk25, it is dedicated to Amig and of course for everyone else. :D
All of you can collaborate with images and information. :wink:
peter_dk25
Drives: Blue GT
ciclo wrote:It is not for me peter_dk25, it is dedicated to Amig and of course for everyone else. :D
So no cold in Spain right now? 8)
Yes, it's cold (personal feeling), but will only be a few weeks and mainly by night when people usually sleep.
Amig
Drives: 2014 6R R-line GTD 2.0
Post by Amig »
Wow Ciclo!
You are really quick! And big effort already! Thank you!!
If there is anything i can do to help you in any way, you know where to find me!
Already is a great help with VCDS autoscan from WRC.
I have a present for you if you want, related to winter package, I'll comment by email. :wink:
Amig
Post by Amig »
Ow!! i like presents!!! :shock:
federicodrdpro
Drives: White Polo 6R TDI
Post by federicodrdpro »
Where can I buy the heating elements? In VW they are very expensive. :?
Ciclo, is possible to use universal heating elements with the OEM unit? :roll:
Like this:
70W
- http://www.ebay.de/itm/Sitzheizung-Carb ... SwR0JUT7VS
- http://www.ebay.de/itm/KFZ-Heizmatten-N ... Swqu9U3iSx
90W
- http://www.ebay.it/itm/WAECO-MSH-50-SIT ... rmvSB=true
The OEM heating elements for Polo are very rare in online shops.
Price of OEM parts in 2012 year:
- http://www.imagebam.com/image/aeda23172553662
federicodrdpro
OEM Thermo Element :mrgreen:
Asamoli
Drives: 1.2 TSI (105) SEL polo 6r
Post by Asamoli »
Where can I buy the heating element from?
Sent from my XT1572 using Tapatalk
federicodrdpro
Hi! Polo 6R OEM thermo elements are very rare and more expensive. You can buy the Seat Toledo/ Skoda Rapid thermo elements for your Polo. They fit perfect in VW Polo 6R. I mounted them and they are perfect! 8)
You can buy them here: http://www.skodaautoteile.de/shop/rapid ... 3001880736
They are the economic OEM thermo element you can buy for your Polo.
Here you can see them:
Federico
CNK
Drives: 6R
Post by CNK »
federicodrdpro wrote:Hi! Polo 6R OEM thermo elements are very rare and more expensive. You can buy the Seat Toledo/ Skoda Rapid thermo elements for your Polo. They fit perfect in VW Polo 6R. I mounted them and they are perfect! 8)
Federico
Wow :shock: Did you have to iron seats after this retrofit? :)
federicodrdpro
Hi CNK :), Do you mean if the seats have a different confort after mounted the heated elements?
The comfort is same of before. :wink:
federicodrdpro wrote:Hi CNK :), Do you mean if the seats have a different confort after mounted the heated elements?
No that is not what he meant, the English language - it can cause problems, "iron" in English = "ferro" in Italia ! ie ferro da stiro
