Due to the manufacturing date, you may need to purchase such a license in order to activate the CCS.
Ask your VW dealer, or search the official VW website for Brazil if they may offer CCS activation for your UP!(ECU).
I do not recommend the process of uploading a different file to your ECU if you are not in expert hands... this should be your last option.
Polobear6r
Drives: Polo
Post by Polobear6r »
I tried to find a wiring diagram for the TRIP OK/Reset stalks but i could not find it. Is there anyone who has an diagram for this? (Paint is more understandable for me than original hahaha :oops: )
I have the 6-bhp 3 cylinder polo 6R
With an normal non + MFD
viewtopic.php?t=65096#p489673
Only three wires, I think it is quite simple.
Polobear6r
Drives: Polo
ciclo wrote: Wed Jun 03, 2020 3:27 am viewtopic.php?t=65096#p489673
Thanks!
I made some changes to Gannu 1 (from Team-BHP) his paint diagram. So this would be the right diagram for my car?
Yes, it's the right diagram for your 6R and your future improvements.
Polobear6r
Drives: Polo
Ok, thanks.
I just retrofitted the new BCM. (from 85 to 87)
I copied over all settings from the old BCM (like this guide click) but now I have an issue with the radio.
To be clear, yesterday I fitted a new Kenwood bt73dab radio. And yes in hindsight I should have made an autoscan after I fitted the new radio. So I’m not sure if my fault codes are related to the new BCM or the new Radio.
The new radio seem to work ok.
In the 19-CAN Gateway module > Installation List i copied the same features that my old car had. The new BCM had 56 - Radio turn on but i turned it off. And saved the settings.
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 002200
   Shop #: WSC 124697 483 00190
   VCID: 70EB2971A3F81406FB-8024
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 235217 km
                    Time Indication: 0
                    Date: 2014.10.31
                    Time: 00:26:32
Address 56: Radio
Cannot be reached
Are these faults related to the fact I have no original VW radio?
I am not sure but i think also the 56 - Radio option is new?
I tried to clear the codes but they keep comming back.
The whole autoscan is here:
Tuesday,09,June,2020,19:55:19:23303
VCDS Version: 20.4.1.0 (x64)
www.Ross-Tech.com
VIN: WVWZZZ6RZCY******   License Plate:
Mileage: 235220km-146158mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZCY******   Mileage: 235220km-146158miles
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CGPB)       Labels:. 03E-906-019-CGP.clb
   Part No SW: 03E 906 019 M    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 8949
   Revision: --------    Serial number:
   Coding: 00110016000400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12MPI02103E906019M 001007
   ROD: EV_ECM12MPI02103E906019A.rod
   VCID: 2E57F709714C42F6A9-807A
Readiness: 0010 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210224E3217000B6842924EB84DA00401100
   VCID: 071962ADB27633BE4A-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 F    HW: 6R0 820 045 F
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 316DEC7568725D0EB4-8064
   Part No SW: 6R0 937 087 H    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0230
   Revision: BF046001    Serial number: 0394 035110798
   Coding: 62B02BBF08A10048002008002D2B0C900040410F60060000200000000000
   VCID: 428FB3B9DDD4D6965D-8016
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU014061100014122
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU016061100013956
   Coding: 08BC30
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00PVUS.
   Coding: 003232
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9F9B99EDE40ED695-801E
   Serial number: 3575HRB404V0JR9KC0K6
   Serial number: 3585HRB40570ISD6CGHU
   Serial number: 3515RRB40530L9U4H1JK
   Serial number: 3525RRB405D0L2V2C8FL
   Part No SW: 6R0 920 860 G    HW: 6R0 920 860 G
   Component: KOMBI         H03 0505
   Coding: 140200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 387BD15183088C46F3-806C
   Coding: 002200
1 Fault Found:
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 235217 km
                    Time Indication: 0
                    Date: 2014.10.31
                    Time: 00:26:32
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADF3B198D24EED6B5-803E
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F69EA0DEA464BFEA2-807A
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:18)--------------------------
The two faults found in the diagnosis are due to the installation of a non-original radio. No problem.
If desired, disable the 56 Radio in 19 Gateway - Installation List, so that such faults do not appear every time you diagnose.
Polobear6r
Drives: Polo
ciclo wrote: Tue Jun 09, 2020 8:08 pm The two faults found in the diagnosis are due to the installation of a non-original radio. No problem.
I thought i already did that. But ill check again to make sure.
Thanks!
Sometimes it is not possible to disable Radio 56 from the GW inst list. I don't know the reason.
mateusr
Drives: Actually a Volkswagen UP
Post by mateusr »
ciclo wrote: Fri Mar 27, 2020 5:40 am R3 1.0 TSI CYTA engine is a version sold in Mexico, Brazil, Argentina, among others (American countries), I have the wiring diagrams for all the UP versions except for your engine.🤷‍♂️
MPI versions = T56/29 (up) or T94/23 (polo 6C).
TSI versions = T94/56 or T94/61
* Depends on manufacturing dates. (and ECU type)
The most likely for your engine due to the manufacturing dates is 56.
Your CD software is more up to date than J, I think both versions of software support CCS.
I don't think it's pin 62, maybe in the following link the one that tried to help you meant pin 61.
https://www.upownersclub.co.uk/threads/ ... ost-129609
According to the VCDS reading the fault is in the wiring, or ECU pin.
Please make an exact drawing of the wiring you have installed.
I suppose to insert the pin into the ECU connector you first removed the pink / purple / vilolet locking mechanism. It is a common mistake because it appears that the pin is inserted but it really is not inserted if you did not remove the locking mechanism. (read this thread) viewtopic.php?f=56&t=65431&start=285#p562849
Hi I'm joining this thread since I have one VW UP too, but not the TSI Model. Besides it has the automated transmission instead of the manual one, I really don't understand what VW did to keep the CCS off this model ¯\_(ツ)_/¯. It has the CSEA engine and I'm trying to do the retrofit too. Do you have the wiring diagram? Thank you!
Hi mateusr.
I have the CSEA engine diagrams for Fox/CrossFox but there is no indication for CCS in this ECU, so the diagrams are not useful in this case.
The pin assigned to the CCS for petrol ECUs with two 56-pin connectors is the T56a/29 ('B' connector) but they are CHYA, CHYB ECUs.
hmm... try it.
Matmaz
Drives: VW Up! TSI xtreme
Post by Matmaz »
Matmaz wrote: Thu Apr 09, 2020 9:37 pm
ciclo wrote: Sat Mar 28, 2020 6:01 am Your fusebox image edited with the crap from Windows 10 tools. :lol:
Two wires reach this fuse SC5, one is black (INPUT - SC5B -) and the other is black-gray (OUTPUT - SC5A -) and you must connect the CCS power wire to the output wire (SC5A).
A or B should be engraved on the plastic on the back of the fuse box.
This fuse is dedicated to powering the reverse light switch (for future reference).
I think it is a good place to connect the CCS power, the other first four fuses are occupied by various important devices or connectors.
Bad news. I put the cable in the output wire and... nothing has been changed. The values still the same and the main switch continue to not response as in the vídeo. A man that was helping me with this told me that I need to take a license to active the function via ODIS and another man told me that my software version won't be able to activate the function and because of this I will need to copy the software from a Up! that have cruise control enable from the factory to use the file to change my ecu. I'm sad about it, but I think that I will buy this universal cruise control https://loja.onmotus.com.br/produtos/throttle-up-vw-up/
Do you think what they told me may be correct? Thanks to all the help anyway.
Hi, everyone. Happy new year!!!!
I have news about the cruise control retrofit in my Up!. The problem was in the stalk, so I have made a derivation between the pin 1 and 2 on the stalk to pass the power and it's solved and now the cruise control is working well. The correct pin in ecu CYTA is the pin 56/T94. Thank you ciclo for the help.
Thanks to you for the report after some time has passed. 8)
I guess this will be very interesting for the UP sold in Brazil, etc ...
Very happy and prosperous year 2021! for the entire South American continent.
Take good care of yourself with personal measures against the pandemic, it is necessary for everyone.
We love you and we need you!
Matmaz
Post by Matmaz »
ciclo wrote: Fri Jan 08, 2021 6:29 pm Thanks to you for the report after some time has passed. 8)
I have installed the cruise control only in december that's way I wait a long time to report. hahaha
But if someone needs help, I will be here to help as much as possible. 8)
I have installed in a another Up! and it's working well too and this retrofit is interesting for the most part of the owners.
I've been taking care against the pandemic. Take care too.
StefanH
Drives: Seat Ibiza 6P 1.2l TSI
Post by StefanH »
Hi I'm new here and really happy about the electrical circuit diagrams.
I tired to update my seat ibiza 1.2 TSI, which should be similar to the polo in the wiring.
I connected now my controller the follwing:
Bildschirmfoto vom 2021-03-03 06-52-13.png (11.63 KiB) Viewed 3218 times
In this wiring I'm missing the diode. I don't know which wire should be the one with the diode.
I'm I right, that ECU has to be connected to Pin 94/45, since it is a 1.2l TSI?
Sorry, that it is not directly a Polo questions, but if I'm right, this should be quite close, isn't it?
I tried several Ibiza forum but with no success.
Thank you a lot in ahead.
