My boot doesn't close properly unless I take the rubber seal out.. But then it just leaks water.. So what would be the solution? Cheers in advance
Boot no closing
Re: Boot no closing
If it's a 6n it'll likeely need adjustment on the top hinges to pull he boot lid away from the chassis to make a bigger gap
Re: Boot no closing
Thanks.. I got a new boot lid going on so will have a look when fitting it
Re: Boot no closing
It's the bit were it latches onto the bottem.. We're the lock is.. Just seems that it is to far away and it will only shut you really really slam it..
Re: Boot no closing
Yeah the top hinges will stop that working
The lower post is also slightly adjustable
