UK-POLOS.NET - THE VW Polo Forum • Christian's Polo 6R < R-Line Mods / Retrofitted xenon
Page 1 of 2
Posted: Mon Mar 30, 2015 6:21 pm
by boomshack
Welcome to Christian's Polo 6r ( Ongoing project! )
Vw Polo 6R - Bluemotion @ 2014
Cornering lights
Fog lights
H4 Halogen
DRL in Fogs
Ac
Heated mirors
First some Pictures of the baby<3
Sound Damping
The Whole car has been covered in Bityl sounddamping and sound foam.
Its an brand new car after that mod, the stereo is 100% better and you cant hear the road noise at all!
http://www.ebay.com/itm/Dammung-Silent- ... 2a13b009c3
Addet to the Car
Wheels: Audi Norwegian 7.5
Coil over: KW v3 Inox
Ice: Custom installed Ipad mini
Grills: GTI top grill - Bottom Highline grill
Seats: R-line leather / alacantra
Waiting to be fitted on the car for the summer!
R-line front bumper with cleaned look ( getting painted atm )
OEM Xenon lights
Looking for some Expert knowledge Retro fitting OEM Xenon lights on my BlueMotion
I bought the originale Xenon lights for my car but im looking for some help with Wiring and Coding, im not even sure my BCM will work?
I know i need a Adapter kabel from 10pin to 14pin but can i code my BCM to work with the xenon lights? or do you need an Higher Nr Bcm?
I have the option in VCDS to change it to Xenon
THANKS ALOT FOR ANY HELP YOU GUYS CAN PROVIDE ME WITH!!
VCDS - AutoScan
Sunday, 29 March, 2015.16: 45: 04: 39,645
VCDS - Windows based VAG / VAS emulator
VCDS version: NEZ 14.10.0.1
Data Version: 20141124
Dealer Number .: 000 00000 262 143
Frame number: WVWZZZ6RZEY080790 Indreg.nr .: AH93757
Driving distance: 97040km Repair Order:
Model Type: 6R (6N0)
Searched on: 01 03 08 09 15 17 19 25 44 56 61 0B
Frame number: WVWZZZ6RZEY080790 Driving distance: 97040km
01-Motor - Status: OK 0000
03-ABS brakes - Status: OK 0000
04 Steering angle - Status: OK 0000
08-Air - Status: OK 0000
09-Centralelektrik - Status: Malfunction 0010
15-Airbags - Status: OK 0000
17-Instrument - Status: OK 0000
19-CAN Gateway - Status: OK 0000
25-Immobiliser - Status: OK 0000
44-Power Steering - Status: OK 0000
56-Radio - Status: Malfunction 0010
61-Battery Control - Status: OK 0000
Control unit 01: Motor (J0000-CFWA) Forklaringsfil: NEZ \ 03P-906-021-CFW.clb
Styreenhedsnr: SW: 03P 906021 AG HW: 03P 907425
Component: R3 1.2 DCM3.7 H10 2637
Revision: 12005003 Serial Number:
Coding: 00114014032401080000
Dealer: WSC 00788 648 00255
ASAM data set: EV_ECM12TDI03103P906021AG 001004
ROD: EV_ECM12TDI_SE25.rod
VCID: 6DDBED4ABC0B2349B4C-8038
No fault codes found.
Readiness: 0000 0000
Controller 03: ABS brakes (J104) Forklaringsfil: NEZ \ 6R0-907-37x-ESP90.clb
Styreenhedsnr: SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0003
Serial Number: --------------
Coding: 21DD2485412B00C0841B2472825100520905
Dealer: WSC 01383 785 00200
ASAM data set: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_AU21.rod
VCID: 0F2797C2D6C7B159E60-805A
Controller 08: Air conditioning (J301) Forklaringsfil: Redirect!
Styreenhedsnr: SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: One AC H02 0202
Revision: 0003SH02
VCID: 3973091AB0C34FE9684-806C
Controller 09: Centralelektrik (J519) Forklaringsfil: NEZ \ 7H0-937-08x-09.clb
Styreenhedsnr: SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 max4 H74 0712
Revision: B9074001 Serial Number: 0571 238 132 638
Coding: 64B02B3F08A10000002009B06C6B0CD05F80412F7E840440A00000020000
Dealer: WSC 64231 001 104857
VCID: 2D5B2D4A748BE349F4C-8078
Under System 1 - Styreenhedsnr: SW: 6R0 959 801 TO HW: 6R0 959 801 TO Forklaringsfil: NEZ \ 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0400A0
Under System 2 - Styreenhedsnr: SW: 6R0 959 802 BE HW: 6R0 959 802 BE Forklaringsfil: NEZ \ 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1400A0
1 error found:
01758 - Light bulbs for brake lights
011 - Termination - Periodic
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Nulstiltæller: 20
Time Indication: 0
Controller 15: Airbags (J234) Forklaringsfil: NEZ \ 5K0-959-655.clb
Styreenhedsnr: SW: 6R0 959 655 L HW: 6R0 959 655 L
Component: VW10Airbag01J H10 0020
Revision: -------- Serial Number: 003GY009LUTD
Coding: 00314A
ASAM data set: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 4B9F43D2E25FCD79CA8-801E
Crash sensor for side airbag on the driver's side:
Serial Number: 3575HRB400850J5QB15U
Crash sensor for side airbag on the passenger side:
Serial Number: 3585HRB400850J5Q7H61
Crash sensor for side airbag, rear driver's side:
Serial Number: 3515RRB400I50L36EPGJ
Crash sensor for side airbag, rear passenger side:
Serial Number: 3525RRB400C50L36LGRN
Controller 17: Instrument (J285) Forklaringsfil: NEZ \ 5K0-920-xxx-17.clb
Styreenhedsnr: SW: 6R0 920 861 M HW: 6R0 920 861 M
Component: COMBI H02 0406
Serial Number: 00000017715099
Coding: 540801
ASAM data set: EV_DashBoardUDSJCIPQ25 A01723
ROD: EV_DashBoardUDSJCIPQ25_VW25.rod
VCID: 3F876702A6E761D9560-806A
Controller 19: CAN Gateway (J533) Forklaringsfil: NEZ \ 6N0-909-901-6R.clb
Styreenhedsnr: SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Coding: 002200
VCID: 70E5F43EA339CEA19FA-8025
Controller 25: Immobiliser (J285) Forklaringsfil: NEZ \ 5K0-920-xxx-25.clb
Styreenhedsnr: SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H02 0025
Serial number:
ASAM data set: EV_ImmobUDSJCIPQ25 A01003
ROD: EV_ImmobUDSJCIPQ25_SK25.rod
VCID: 6AD1E6568DE53471D1E-803F
Controller 44: Power steering Forklaringsfil: NEZ \ 6Q0-423-156.clb
Styreenhedsnr :: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11230
Dealer: WSC 00788
VCID: 3065343EF7B98EA1DFA-8065
Controller 56: Radio (J503) Forklaringsfil: NEZ \ 5M0-035-1xx-56.clb
Styreenhedsnr: SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 042 0082
Revision: 01000001 Serial Number: VWZ1Z2N1653297
Coding: 05000400020001
VCID: 336F3B3292AFB5B9A28-8066
1 error found:
03138 - Input AUX IN
011 - Interruption
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Nulstiltæller: 240
Driving distance: 71815 km
Time Indication: 0
Date: 12/11/2014
Time: 15:23:07
Controller 61: Battery Control (J840) Forklaringsfil: NEZ \ 1K0-907-534.clb
Styreenhedsnr: SW: 7H0 907 534 HW: 7H0 937 090
Component: Batt.regelung H74 0712
Serial number: 0571 238132638
Coding: 030B1A59
VCID: 6BDFE3528A1F2D79AA8-803E
Under System 1 - Styreenhedsnr: SW: 6R0 915 181 E HW: 6R0 915 181 E
Component: J367-BDM H08 0181
Containment ---------------------- (Elapsed time: 02:20) ------------------- -----
Re: Christian's 6r - Retroffing Xenon and need some Advice!
Posted: Mon Mar 30, 2015 6:51 pm
by Mart!n-GTI-DK
Velkommen ombord. :) Eller må hellere holde det på engelsk så alle ka følge med. ;) Men lækkert at se endnu en dansker herinde. :)
Welcome to the forum. :)
Ciclo In here has posted a guide to fit bi-xenons to the Bluemotion just a few weeks ago. And he is allways ready to give som helpfull advice. :)
Retrofitting OEM Xenon on a POLO 6R BlueMotion.
Posted: Mon Mar 30, 2015 7:01 pm
by iichel
No your Bluemotion BCM will work perfectly with the xenon headlights.
You do need an adapter from 10 to 14 pins. I have made my own with help from ciclo and I will post a guide how to do it as soon as I have time.
ciclo is the expert on coding. But it will work :) don't change your bcm
Posted: Mon Mar 30, 2015 7:37 pm
by boomshack
iichel wrote:No your Bluemotion BCM will work perfectly with the xenon headlights.
thats sounds awesome!
Ive ordered a harness today , but what about the coding?
Should i just change the Light settings to Xenon?
Also, the harness has an extra wire i need to connect to the BCM right? will my BCM have thos 2 pins?
Posted: Mon Mar 30, 2015 9:04 pm
by ciclo
Welcome boomshack, very good intro. I like much work you did for noise reduction, already knew it from Danish forum. :wink:
Your BCM is simply the best, it has all the necessary pins for OEM xenon retrofit.
For coding, do not worry, I make the coding for you.
First is to prepare the harness 10-14.
This is exactly what you have to do:
http://www.uk-polos.net/view ... 19#p492319
Posted: Tue Mar 31, 2015 12:38 am
by saty
Polo looks great, love the interior
Ure grill set up is exactly like mine :wink:
Posted: Tue Mar 31, 2015 8:14 am
by ciclo
This is the encoding to work xenon headlights in your Polo BM.
64B02BBF08A10000202009916E6B0CD05AC0472F7E051440A00000020000
...copy and paste as indicated in point 20 of this installation guide: https://drive.google.com/file/d/0B2nv91 ... E1bk0/edit
You must enter this code after setting the harness and all required cables correctly. Not before.
Taking advantage that you will make these changes in the cables for better lighting in the headlights, my recommendation:
- Install dimming rearview mirror with light-rain sensor.
Info, e.g:
http://www.uk-polos.net/view ... 32#p492923
http://www.uk-polos.net/view ... 24#p492795
http://forums.vwvortex.com/showthread.p ... st73565527
http://www.touranklub.pl/forum/viewtopic.php?f=24&t=953
- Install auto-light "wiring". CH/LH
You get many functions of driver assistance.
All this is possible with your BCM, but we will have to change the coding if you install these systems.
Posted: Tue Mar 31, 2015 6:48 pm
by boomshack
ciclo wrote:Welcome boomshack, very good intro. I like much work you did for noise reduction, already knew it from Danish forum. :wink:
Yhm wow :D
Know i know why im a carpenter and not working with EL , Jesus hehe..
This is what im gonna order for the Harness " http://www.ebay.com/itm/Xenon-Bi-Xenon- ... 0722286520 "
then if im reading the diagram right, i need to get a wire from Pin 14 to my fog lightDR and then to the BCM right? :p
Any idea what the Connector is called at my Fog lights so i can order does and make a splitter?
Posted: Tue Mar 31, 2015 6:49 pm
by boomshack
ciclo wrote:This is the encoding to work xenon headlights in your Polo BM.
Info, e.g:
i dont have a Rain sensor on my car so i cant get Auto light :(
Posted: Tue Mar 31, 2015 6:51 pm
by boomshack
Seems Easy enough :D haha ...
WTB Adapter harness for the fogs :D
Posted: Tue Mar 31, 2015 7:50 pm
by ciclo
It's pretty easy. iichel soon will post a guide to do it even easier, and if you do not understand the guide, we will gladly explain it. :wink:
Image VS Image
Posted: Tue Mar 31, 2015 8:03 pm
by boomshack
ciclo wrote:It's pretty easy. iichel soon will post a guide to do it even easier, and if you do not understand the guide, we will gladly explain it. :wink:
Image VS Image
Sounds good!
im like a small boy before X-Mas, cant wait to get those fitted - Summer inc <3
Christian's Polo 6R< R-Line Mod / Retrofitted xenon | UPDATE
Posted: Sun May 10, 2015 7:40 pm
by boomshack
Summer Update!
R-Line front bumper with all painted plastic fitted
Org Oem Xenon
Summer Wheels painted in Oem white as the car
New Adapters to get fitment 100%
Modified Suspesion with only 70% lowered so i can go even lower but i think fitmen is 100% now
100% Paint correction by myself - around 30 man hours
what do you guys think?
Re: Christian's Polo 6R < R-Line Mods / Retrofitted xenon
Posted: Mon May 11, 2015 5:19 am
by ciclo
Really nice improvements, "good job".
I guess you did not have problems with the LED module. Right?
Posted: Mon May 11, 2015 11:02 am
by boomshack
We did something else because of the flashing at the time, so the led is on 100% all the time..
We might change it now since iicle figurede out the problem, i have to ask him how much of the harness we need to redo
