Changing the daytime running lights to LEDs on a Polo 6c
nskittles
- Drives: Volkswagen Polo SE 1.2 TSI Bluemotion 6c
I was wondering if it is possible to change the daytime running lights to LEDs or at least to a bulb that it whiter on a Polo 6c? If so is it difficult/expensive?
Doc_House
- Drives: 2015 VW Polo SE and 1972 GT Beetle
Re: Changing the daytime running lights to LEDs on a Polo 6c
dead easy...
You'll need some cree bulbs from here http://www.horizonleds.co.uk/cree-leds/ did mine a day after I have it and it looks so much better than the yellow stock bulbs.
Front clips come off easily but the plastic tabs can be brittle took about 10 minutes to fix.
Wellsy1234
- Drives: Polo 6C SE
Did you have any errors come up after changing the bulbs to LED's
- Robby71
- Drives: 2019 Golf R-Line EVO
I fitted a pair of these as recommended by others on here - http://www.hids-direct.co.uk/382-p21w-w ... anbus-led/ crisp white light and no errors
