UK-POLOS.NET - THE VW Polo Forum • Any one else got fogged up headlights?
Posted: Sun Jul 26, 2015 10:42 am
by Doc_House
Noticed after Friday's down pours, both headlights were fogged up quite badly with only the area around the main dipped beams clear. I've checked all the seals and caps and they're all intact. Just wondered if there is something else or if it was just because the of the weather.
Re: Any one else got fogged up headlights?
Posted: Sun Jul 26, 2015 11:54 am
by Mart!n-GTI-DK
Doc_House wrote:Noticed after Friday's down pours, both headlights were fogged up quite badly with only the area around the main dipped beams clear. I've checked all the seals and caps and they're all intact. Just wondered if there is something else or if it was just because the of the weather.
It's most likely just because of the weather...
Posted: Sun Jul 26, 2015 5:05 pm
by Guy
Extract from the manual :-
In cool or damp weather, the interior of the headlights, rear lights and turn signals may mist up briefly.
This is normal and does not affect the service life of the lights on your vehicle.
Posted: Mon Jul 27, 2015 10:34 am
by Doc_House
Posted: Mon Jul 27, 2015 11:03 am
by daveb73
I think they have a breather hole/pipe as part of the design which helps dispel the condensation, this means they may well mist up but will clear soon afterwards.
Posted: Tue Jul 28, 2015 10:34 am
by TheFrog
I've had this problem on BMWs and Jaguars in the past (but not my Polo so far...). The vent holes occasionally allow moisture into the housing, but they are designed to clear/vent as soon as you take the car out again.
