9N drivers door central locking removal help
Posted: Sat Sep 05, 2015 12:59 pm
by TonyP
1st post & requesting help (sorry
My drivers side central locking motor is intermittent & mostly now doesn't work, I've got the central locking motor almost out bar the short bowden cable connecting between the external handle & the central locking unit.
Can anyone tell me how to disconnect this cable so that I can completely remove the central locking unit please, it doesn't seem obvious.
Any help much appreciated right now as I'm a bit stuck
Car is a 2003 9N 5 door.
Tony
Re: 9N drivers door central locking removal help
Posted: Sun Sep 06, 2015 8:41 am
by TonyP
Sussed it, just had to line it up in a certain way & it comes out, what a complete PITA it is to remove the whole door lock mechanism though
but once out I dismantled the lock with the intention of re-soldering the connections as per a youtube video, I couldn't do this as the PCB is covered in a varnish, anyway on the basis that I had nothing to lose I sprayed the microswitches with contact cleaner, upon reassembly back into the car so far it seems ok
If nothing else having done the job once already & should it fail again I know how to swap it with a new one & I also made a note of the part number whilst it was out.
Pattern doorlocks ok? or should I go OEM only?
Tony
Posted: Sun Sep 06, 2015 7:32 pm
by alexperkins
Go OEM only. The copy locks are awful quality and just fail!
Posted: Sun Sep 06, 2015 11:28 pm
by TonyP
Thank-you, OEM it is then, anyone have a rough idea on price from the dealers should I need one?
Posted: Mon Sep 07, 2015 10:27 am
by alexperkins
£90 ish last time I bought one
Posted: Mon Sep 07, 2015 11:54 am
by TonyP
Thanks Alex
Posted: Mon Sep 07, 2015 11:56 am
by TonyP
PS, small world Alex, just noticed you are from Poole, I'm not far away in Broadstone.
Posted: Mon Sep 07, 2015 12:18 pm
by alexperkins
I'm actually in Broadstone. Poole just keeps it indescript ha
