UK-POLOS.NET - THE VW Polo Forum • errors with VCDS diagnosis
Posted: Tue Sep 08, 2015 5:32 pm
by Bachecco
hi friends, I have this errors with VCDS diagnosis. Maybe the problem was created when I get off rear bumper and sensors for mounting the rear view camera without disconnecting the battery because before I had no errors.
Time ago I activated some functions but don't know if the problem is due to this, the functions are: Bluetooth OEM with Push to talk, TPMS, AUX-IN, trip computer and automatic closing door. I hope you can help me
Saturday,27,June,2015,12:41:22:37412
VCDS Version: Release 11.11.0
Data version: 20111111
Chassis Type: 6N0
Scan: 01 03 08 09 10 15 17 19 25 37 44 55 56 77 0B
VIN: WVWZZZ6RZBY277278
10-Park/Steer Assist -- Status: Cannot be reached 1100
37-Navigation -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
Address 01: Engine (J623-CGPA) Labels: None
Part No SW: 03E 906 019 B HW: 03E 906 019 B
Component: SIMOS11.1 H03 9878
Revision: --H03--- Serial number:
Coding: 00110016000400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12MPI02103E906019B 001011
ROD: EV_ECM12MPI02103E906019B.rod
VCID: 234F9E282ACEE76
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6J0-907-37x-ESP.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210224E3217400B9842724E984D900401300
VCID: 87176AB83236AB6
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 32616B6C6D347EE
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 D HW: 7H0 937 089
Component: BCM T5GP Li4 H47 0230
Revision: BS047001 Serial number: 0398 078111260
Coding: 3CB02BBF08A10000003808B17C2B0DD15AC8670F60051041200000000000
VCID: 37775A7886569B6
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 1611
Coding: 08BC30
Subsystem 3 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H07 0013
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 007 1611
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 007 1611
Coding: 08BC32
Address 10: Park/Steer Assist
Cannot be reached
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00HMGR5
Coding: 003232
VCID: 4A91138CEDA416E
Crash sensor for side airbag; driver side:
Serial number: 3575HRB40570DUOG79P0
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB40590DUOG2PB0
Crash sensor for side airbag; rear driver side:
Serial number: 3515RRB404R0H1GGCGT6
Crash sensor for side airbag; rear passenger side:
Serial number: 3525RRB404T0H1GGC89O
Part No SW: 6R0 920 860 F HW: 6R0 920 860 F
Component: KOMBI H05 0304
Coding: 140E00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 37775A788E569B6
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 0230
Coding: 002200
VCID: F0E5216423B88CE
1 Fault Found:
03075 - Parallel Parking Assistance Control Module (J791)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 39030 km
Time Indication: 0
Date: 2104.14.25
Time: 15:19:08
Component: IMMO H05 0304
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: EAD1330C0D6476E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 F HW: 1T0 035 680 F
Component: RNS-MID H55 3970
Revision: AB001001 Serial number: VWZ6Z7L9185093
Coding: 04000442040000900000
Shop #: WSC 01357 011 00200
ASAM Dataset: ------------------------- ------
VCID: 316364606832456
5 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 254
Reset counter: 99
Mileage: 39024 km
Time Indication: 0
00876 - Treble Speaker Rear Left (R14)
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 134
Mileage: 44928 km
Time Indication: 0
00877 - Treble Speaker Rear Right (R16)
Fault Priority: 5
Fault Frequency: 3
Reset counter: 134
Mileage: 44928 km
Time Indication: 0
02873 - Control Module for Back-Up Camera (J772)
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 3
Reset counter: 139
Mileage: 44944 km
Time Indication: 0
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 39800 km
Time Indication: 0
Date: 2106.14.02
Time: 16:25:23
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F676218EA06536
Address 55: Xenon Range (J431) Labels: None
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0110000001000000
VCID: F7F71A784ED6DB6
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
5 Faults Found:
011 - Open Circuit
Fault Priority: 5
Reset counter: 99
Mileage: 39024 km
Time Indication: 0
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 4
Reset counter: 99
Mileage: 44928 km
Time Indication: 0
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 4
Reset counter: 99
Mileage: 44928 km
Time Indication: 0
Fault Priority: 5
Fault Frequency: 3
Reset counter: 139
Mileage: 44944 km
Time Indication: 0
Fault Priority: 5
Fault Frequency: 1
Reset counter: 139
Mileage: 39800 km
Time Indication: 0
Date: 2106.14.02
Time: 16:25:23
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663112816
Coding: 0400000000010110
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_VW25.rod
VCID: 3B7F4648B27EBF6
Address 0B: Sec. Air Heating
Cannot be reached
End ---------------------------------------------------------------------
Re: errors with VCDS diagnosis
Posted: Tue Sep 08, 2015 5:51 pm
by iichel
does your pdc still work?
Posted: Tue Sep 08, 2015 5:57 pm
by ciclo
http://wiki.ross-tech.com/wiki/index.php/03075
Firstly:
- Fuse SB16 5Amp
- Check connectors
Codings seem quite right, we wait your checkings. :wink:
Posted: Wed Sep 09, 2015 12:36 am
by Bachecco
iichel wrote:does your pdc still work?
Yes, my PDC still work now.
ciclo wrote:http://wiki.ross-tech.com/wiki/index.php/03075
Firstly:
- Fuse SB16 5Amp
- Check connectors
I checked the fuse SB16 but my sensors were installed after in the dealership and then I haven't fuse in that position:
I checked the connections and it's ok. I also took picture of sensor module: Image
PS.
I have found a diagram of my unit on Internet:
Model: GT parking system GTPS3
Inviato utilizzando Tapatalk
Posted: Wed Sep 09, 2015 9:51 am
by ciclo
Well, now it all makes more sense.
Perhaps it is a simple software problem, the best thing to do is go where the system was installed and they check the control unit.
Posted: Fri Sep 11, 2015 3:57 pm
by Bachecco
Ok, but my main problem is that I have activated the rear view camera and on the display now I see all black when I insert the reverse.
I thought that everything depended on the fact that I hadn't activated the functions on module 10- park/steer assist, but as you can see:
the camera view appears on the display when I enter the reverse though all it's black.
I saw some videos on the web and they activated the rear view camera only activated the function in the module 37- navigation. In fact if I hadn't had parking sensors however I would not be able to enter in the module 10- park steer assists.
What could be the problem?
Posted: Fri Sep 11, 2015 5:08 pm
by ciclo
Try this:
Disconnect and reconnect camera connector, the same operation with orange wire-->connector on GTParsystem (centralina).
Posted: Fri Sep 11, 2015 5:20 pm
by Bachecco
I leave the battery connected? I disconnect both connectors of the rear view camera?
Posted: Tue Sep 15, 2015 9:23 pm
by ciclo
Sorry for taking so long to reply. (lately ...)
No & Yes to both questions, in that order.
Perhaps you have already solved this problem.
Posted: Wed Sep 16, 2015 9:07 am
by Bachecco
unfortunately no!
This morning I spoke with the company GT and they told me that the unit isn't recognized by the software volkswagen but only activates the bit 10- park/steer assists in module 19- can-gateway.
I tried to deactivate the parking sensors from the can-gateway but when I insert the reverse I see all black on the display :(
Posted: Tue Oct 06, 2015 2:06 pm
by Bachecco
I spoke with the seller from whom I bought the rear view camera and he should send another replacement because it would be to give problems
