Polo 9N3 dash tray removal.
Posted: Tue Oct 06, 2015 10:19 am
by coopern
Dash tray, no lid. If anyone has removed the little tray in the top of the dash could they please say how it can be done without damaging the dash plastic. I know the tray has grippers/hooks underneath, maybe it can be pulled out using fingers?
N
Re: Polo 9N3 dash tray removal.
Posted: Tue Oct 06, 2015 12:56 pm
by RUM4MO
That is how I removed the one in my wife's late 2002 Polo when I decided to replace it with the version with the hinged top. She never did like the hinged top one and I can see why VW did not push that accessory as the hinging mechanism makes noises all the time! It does look good though, and that was what sold it for me, that and the fact that I had the choice to change/upgrade something.
Posted: Tue Oct 06, 2015 9:53 pm
by coopern
Thanks for that, so I can use my fingers.
It seems to be stuck fast, should I try and pull it up first from the front or the back?
N
Posted: Wed Oct 07, 2015 11:14 am
by RUM4MO
Sorry, I can not remember, but I'd think that I just used my nails - can you not put both hands into it and wedge them against the front and rear and ease it up? If it is a secondhand car, the previous owner might have glued it down to stop it creaking, I'll see if I can find the original one to check how it fits/grips and get back to you.
Posted: Wed Oct 07, 2015 2:58 pm
by RUM4MO
Okay, as we don't have a 9N Polo now and I've looked at the old tray, the end which has the sloping face - either front or rear end, is the one that has hard lugs on it, so do not attempt to lift that end up, all other three sides/ends have lugs that can flex. The lugs that can flex on the sides are at the opposite end to these sides to the sloping face, only one per side and approx. one inch in from the corner, the end opposite the sloping end, has two lugs that can flex and they are approx. 3/4 inch in from the corner.
So to round up, the end of that tray with the recessed or concave face is the face to grab and lift.
If anyone is interested, the replacement tray - ie box with hinged lid is VAG P/N 6Q0 857 465 A/1QA and is called a shelf(??) by VAG.
Posted: Fri Oct 09, 2015 1:02 pm
by coopern
Okay thanks, I'll check it out.
