Replica GT/GTI xenons on 6C
aaygen
Drives: 6C 1.2 TSI Lounge
Post by aaygen »
Hi all,
I'm thinking about buying the replica xenons with LED DRL's that are available for the 6R but I don't know if they fit the 6C electronically. Is the headlight plug same as the 6R and would it work straight away like it's a 6R?
Re: Replica GT/GTI xenons on 6C
the dectane replicas are more or less a straight fit, however i'm not sure you'll have a light bulb error for the LED strip
aaygen
Post by aaygen »
iichel wrote:the dectane replicas are more or less a straight fit, however i'm not sure you'll have a light bulb error for the LED strip
Thanks! If I fit them and they throw a bulb out error, would I be able to fix it with VCDS?
yes
frank.mehta
Post by frank.mehta »
How is the light throw from these dectanes? Can someone who's used them extensively tell us?
