Anybody tried this VW Auto Headlight Light Sensor Switch?
sendoc
- Drives: polo match 1.4 (6R) & Toyota Avensis T3
As the title says, has anybody installed this switch seen in aliexpress website?
Please see link below
http://www.aliexpress.com/item/Newest-V ... 27137.html
I am planning to buy this and set up the CH/LH function.
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Re: Anybody tried this VW Auto Headlight Light Sensor Switch?
I have seen it on other VW's. Works fine.
Without sounding too naive, but what does it actually do?
- Mart!n-GTI-DK
It's aftermarket Autolight & Coming- / Leaving home light.chrispy. wrote:Without sounding too naive, but what does it actually do?
haflidij
- Drives: Polo 1.4 2013 6R
Is it just plug and play ?. I would be interested if it works like that.Mart!n-GTI-DK wrote:It's aftermarket Autolight & Coming- / Leaving home light.chrispy. wrote:Without sounding too naive, but what does it actually do?
yes it is plug and play. learn some dutch and go to forum.mypolo.nl, plenty of experience there :p
I had one of these in my 6R. Worked very well. Literally plug and play
Readily available on ebay UK too - Its the same as the Mk4 golf.
Where do you put the sensor? somewhere on the windscreen?
Just tuck it up the top of the A pillar trim facing the windscreen
sendoc
@ alexperkinsalexperkins wrote:I had one of these in my 6R. Worked very well. Literally plug and play
Got mine today in post.
How do you setup the coming home/leaving home function?
The chinglish instruction is so confusing.
It's automatic. You just need to connect the red wire - presume it still has one of them?
The new mode might be plug and play straight off now
From what I can tell you need to tape off the TFL pin on the headlight loom that plugs into the kit to get the CH/LH working
sendoc
Thanks for the quick reply.It's the new model .No red wire in the module.alexperkins wrote:From what I can tell you need to tape off the TFL pin on the headlight loom that plugs into the kit to get the CH/LH working
I haven't masked the TFL pin yet.Is that the pin for disabling DRL?.
Yes same pin. Without masking that off the auto lights won't work anyway
i ve tried that, but not long before i resumed my original light switch.
the biggest problem is when i drive under the shadow of a bridge, or something like that, the switch quickly turns on. But 3 seconds after i ride through, it will need another 6 seconds to turn off.
when i drive through a small tunnel, the same happens.
i am in china and i DIY something to my Polo. Believe me you will not like it.
