Page 1 of 2
Ordering a Thermostat
Posted: Thu Jan 28, 2016 5:31 pm
by Adriandiamond
How do I tell whether my 6N2 is a 54 or 60 HP model. I'm trying to buy a thermostat on ebay but I get a choice of 2......
Engine Code. AKK VW Polo 2001 6N2 [1999-2001] Hatchback Hatchback 1.4 1390ccm 60HP 44KW (Petrol)
Engine Code. AKP VW Polo 2001 6N2 [1999-2001] Hatchback Hatchback 1.4 1390ccm 54HP 40KW (Petrol)
I've looked at the log book but that tells me nothing.
The part is a Febi Bilstein OE quality coolant thermostat......£6.85 free delivery
Re: Ordering a Thermostat
Posted: Thu Jan 28, 2016 5:55 pm
by TRiBaL
Doesn't matter. Both get the same part.
The thermostat you're looking for is the 032121110B and i would strongly advise to get a genuine vw part.
Posted: Thu Jan 28, 2016 6:22 pm
by Adriandiamond
TRiBaL wrote:Doesn't matter. Both get the same part.
I've just checked that number on Ebay and it says it's not compatible with my vehicle....................
Confused.com
Posted: Thu Jan 28, 2016 6:29 pm
by TRiBaL
Unless you have a gti, which you don't, this is the correct one.
I double checked with ETKA.
Alex can confirm this.
(ebay compatibility catalogues are not trustworthy)
Posted: Thu Jan 28, 2016 6:46 pm
by Adriandiamond
Hi Tribal and thanks for your advice. I've looked on Ebay for a VW part and found this. Would you say this is correct.
It is compatible with the above 2 versions of vehicle in my previous post.
Posted: Thu Jan 28, 2016 10:43 pm
by alexperkins
Febi 17902 is the comparable part number
I would normally recommend going for genuine VW but Febi are very good quality and would have no hesitation recommending them for this
eBay catalogues are often incorrect
Posted: Fri Jan 29, 2016 8:55 am
by Adriandiamond
Thanks again guys for your input. Part now ordered and should be here Tuesday 2nd.
Can I just ask, is there a site or book where all these VW and comparable item no.s can be searched?
Posted: Fri Jan 29, 2016 11:52 am
by alexperkins
Posted: Fri Jan 29, 2016 12:03 pm
by Adriandiamond
Cheers Alex, I've just registered. All I have to do now is try to understand it.
Posted: Fri Jan 29, 2016 12:17 pm
by alexperkins
On the enter part number, you can put in a VW part number and it will give you the febi equivalent
Otherwise, go to catalogue, stick in your reg and itll show all the compatible parts.
Posted: Fri Jan 29, 2016 12:23 pm
by Adriandiamond
If I type in thermostat it comes up with 2 different part numbers. Will either one of these do for my car or am I missing something?
Posted: Fri Jan 29, 2016 12:42 pm
by alexperkins
You click the little i next to the item line
17902 has an 87C opening temp (normal use)
17922 has an 80c opening temp (warm countries)
Posted: Fri Jan 29, 2016 12:43 pm
by alexperkins
You'll want 17902 - just make sure you havent ordered 17922 as youll want to call them and get it changed if so.
Posted: Fri Jan 29, 2016 1:24 pm
by Adriandiamond
Cheers Alex you're a star. Gonna go through the car this afty and make a list of bits needed, shouldn't be that much now but I want it as good as I can get it for when my lad passes his test.
Posted: Fri Jan 29, 2016 7:58 pm
by piglet14
You may find there will be a variance between your definition of 'as good as I can get it' and the lads.
ie. coloured LED sidelight bulbs, silly tyres etc. etc.
