Hi guys,
Has anyone upgraded the master cylinder (brakes)?
I want to upgrade mine and I would like to know if there is any upgraded master cylinder that fits my 6n2 GTI.
Thanks,
Alon
Upgrading master cylinder
Re: Upgrading master cylinder
The seat Ibiza cupra from the same era has a larger (stubby) master cylinder
Depends on what you are pairing it to brake wise though
GTI calipers
G60 Carriers
HEL braided brake lines
280 mm Brembo plates
Ate brake pads - Will be replaced with something better as Ferodo (Hopefully this weekend)
G60 Carriers
I wouldnt think youll need an upgrade with that setup
I ran G60 brakes on my GTI for years and never suffered at all.
- Drives: 6n gti ajv
Hi guys ; )
Im new here,my name is chris,i was looking for information about master cylinder upgrade and i found that topic.
I have a 6n gti i upgrade brakes with 280mm disk and g60 pads.
I want install audi s2 calipers, double pots,can i keep my origine master cylinder or i must replace it ?
Thanks for all informations you can give me ; )
I would look to use a seat Ibiza cubra stubby 28mm master cylinder
28 mm cupra ok.Is it plug and play?
ty
ty
Should be
Do you have a reference please?
thank you
thank you
6K2611019E
Typo earlier. It's 23.8mm
