Polo 6R lowering springs
Posted: Sun May 15, 2016 9:41 am
by Will6R
Hi, just bought a set of h&r 25/40mm lowering springs for my 1.2tsi but still unsure if I should fit them or not? What's the ride gonna be like? Will it cause any damage to the dampers and stuff? Also will it scrape on things it normally wouldn't? Thanks
Re: Polo 6R lowering springs
Posted: Wed Jun 22, 2016 7:48 pm
by Absolutepolo
Hi there. I bought genuine lowering springs from vw for my 6r 1.2tsi. No scrapping. rides as little bit firmer but nothing uncomfortable. Looks good to. Not to low either so i can get over speed bumps. Hope this helps.
Posted: Wed Jun 22, 2016 9:34 pm
by haflidij
Will6R wrote:Hi, just bought a set of h&r 25/40mm lowering springs for my 1.2tsi but still unsure if I should fit them or not? What's the ride gonna be like? Will it cause any damage to the dampers and stuff? Also will it scrape on things it normally wouldn't? Thanks
I have the H&R 35/55mm lowering springs . The ride is way lower of course and its firmer. Going over speed bumps isn't a problem for me , the biggest problem is going in and out of car lots that have that raised up curb from the street it self.
But the only thing that's scraping is the mudflaps so the car itself isn't getting any damage. Also i havent had any problems with my dampers and ive had mine in since around May of last year.
Soooo...Haha all in all you should be good :P
Posted: Tue Oct 04, 2016 12:26 pm
by smelliot
hi i was wondering if you have any picture of your polo on these lowering spings as im in the middle of getting 25mm/40mm or 35mm/55mm but not sure how would sit on my 6r gti
Posted: Tue Oct 04, 2016 12:33 pm
by haflidij
This is mine on 35/55 H&R springs.
Posted: Tue Oct 04, 2016 12:38 pm
by smelliot
is that on the 17" just trying to get an idea as dont want my gti too low but stock it has way to much arch gap and since having it remapped is not sticking to the corners that well
Posted: Tue Oct 04, 2016 2:28 pm
by peter_dk25
H&R 25/40 on 17" :
Posted: Tue Oct 04, 2016 3:11 pm
by smelliot
peter_dk25 wrote:H&R 25/40 on 17" :
thanks alot guys think i might go the 25mm/40mm as looks nice and isnt too low
Posted: Tue Oct 04, 2016 4:35 pm
by smelliot
do you know weight i would use for the gti is it
Image 1
H&R Spring Kit Polo 6R (06/09>) - Front Axle From 930kg
or would it be
H&R Spring Kit Polo 6R (06/09>) - Front Axle Upto >929kg
Posted: Tue Oct 04, 2016 11:47 pm
by haflidij
Hey again. This is on 16'' Here is a better photo maybe.
https://postimg.org/image/y387e5qo5/
Posted: Wed Oct 05, 2016 2:18 pm
by peter_dk25
"do you know weight i would use for the gti is it
Image 1
or would it be
H&R Spring Kit Polo 6R (06/09>) - Front Axle Upto >929kg"
Not easy to say - find the 6R GTI here:
http://www.h-r.com/en/produktfinder.html#
I think the PR-codes for your car gives the answer...
