Today I partially removed the front of the headlining and checked that the front pipe was secure (it is!) - so I then squirted some water down both side front drains and on the nearside the water came out at the mudguard - nothing at all came out of the offside.I then did a comparison visual check - on the nearside in between the door hinges the drain hose exits out of the side of the car and goes down to the mudguard.On the offside there is no pipe and the rubber bung appears to have been capped off LOL
I am assuming both sides should be similar
Does anybody have a part number for the bung and lower drain pipe please ?
