Polo 6R ABS CODING
- habib_123
- Drives: Polo 6R 2012 1.2TDI RHD
Polo 6R ABS CODING
Can anyone post their Polo 6R ABS Coding for me. I have lost mine.
I own a VW Polo 6R 2011 1.2 TDI RHD 5 Door.
Thank You!!
This is the Auto-Scan:
VCDS Version: Release 15.7.4 (x64) Running on Windows 8.1 x64
Data version: 20160216
http://www.Ross-Tech.com
Friday,20,May,2016,21:11:49:33719
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 10 15 17 19 25 2E 37 44 56 77
VIN: WVWZZZ6RZCU015153 Mileage: 48200km-29950miles
03-ABS Brakes -- Status: Not registered 0011
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J0000-CFWA) Labels: 03P-906-021-CFW.clb
Part No SW: 03P 906 021 A HW: 03P 907 425 A
Component: R3 1.2 DCM3.7 H06 8411
Revision: 11002001 Serial number:
Coding: 00114010002500080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TDI03103P906021A 001010
ROD: EV_ECM12TDI03103P906021.rod
VCID: 26438C535964BA0E24-8072
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 31414 790 31414
VCID: 071DE1D7B2AE83063F-8052
4 Faults Found:
03306 - Coding Not Valid
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 4
Reset counter: 96
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:04:03
Hex Value: 0x0002
Hex Value: 0x0002
Hex Value: 0x12E7
Hex Value: 0x259D
Hex Value: 0x00FF
Hex Value: 0x7F81
Hex Value: 0x7FF8
01042 - Control Module; Not Coded
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 56
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:08:05
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1213
Hex Value: 0x149D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 1
Reset counter: 56
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:08:05
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1B9D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
Fault Priority: 0
Fault Frequency: 1
Reset counter: 56
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:08:05
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x209D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
End-------------------------(Elapsed Time: 02:45)--------------------------
Thank You!!
Revision: --------
4 Faults Found:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 96
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:04:03
Hex Value: 0x0002
Hex Value: 0x0002
Hex Value: 0x12E7
Hex Value: 0x259D
Hex Value: 0x00FF
Hex Value: 0x7F81
Hex Value: 0x7FF8
000 - -
Fault Priority: 0
Fault Frequency: 1
Reset counter: 56
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:08:05
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1213
Hex Value: 0x149D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Priority: 0
Fault Frequency: 1
Reset counter: 56
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:08:05
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1B9D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Priority: 0
Fault Frequency: 1
Reset counter: 56
Mileage: 48207 km
Time Indication: 0
Date: 2016.05.19
Time: 21:08:05
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x209D
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Re: Polo 6R ABS CODING
Look in the logs folder VCDS program, If you have made other autoscan...
The ABS coding is related to VIN number, so perhaps the only valid encoding is the original. (I do not know for sure)
How you lost this coding?
- habib_123
Hi Ciclo,
When I bought the car in Feb 2015, it was already like that. The previous owner did something to it. I was hoping someone code could work out the coding or paste theirs with the same spec as mine.
I have the tire pressure sensor installed as well.
210224E3416E00B7842624E782D400521300 (according to your VIN), but Byte15 (52 Hex) is for LHD.
Maybe Byte15 is 92 according to http://vwclub.co.za/forum/viewtopic.php ... 9#p1694595
Try with 210224E3416E00B7842624E782D400921300
- habib_123
Hi Ciclo,
You have outdone me again. i swear you are a genius with the new polos. I will try the coding later on and I will tell you, if it has worked.
Thanks!!!!
Thanks!!!!
True that.
For reference, 2010 Polo 6R Bluemotion
VIN: WVWZZZ6RZBY179829
Revision: --------
Coding: 210224E3417400BB842D24E482DA00521300
Shop #: WSC 00788 648 00255
VCID: 8717035C32D37526559-80D2
Revision: --------
- habib_123
Hi iichel,
Is that coding for LHD or for RHD?
And do you have the TPMS installed?
this is is a LHD polo. it has TPMS
- habib_123
Thanks. I will try that as well but change byte 15 to RHD.
You probably have to do the basic setting of the sensors indicated in autoscan.
We wait the results. (I hope that lady luck be your ally
Perhaps the next link will also help you http://forums.ross-tech.com/showthread. ... ule-please (Byte16 must be 13Hex)
- habib_123
Hi Ciclo,
My brother took the car to London today. He will be back within a few hours and then I will try it. I hope it works. How do I do settings of the sensors?
I think this is the best procedure http://wiki.ross-tech.com/wiki/index.ph ... ic_Setting
But keep in mind the group 63 according to this http://forums.ross-tech.com/showthread. ... #post11788
When you try to do it, everything will be clearer for you. (or not
- habib_123
Thanks Ciclo,
I understand most of it. I have not tried the coding yet. I'm probably gonna have to do it tomorrow as it's 8pm here and my brother will be back late. I will notify you when i've done it. But thanks for these links. They are VERY useful.
The coding is based on your VIN number, so is very likely to work.
You have to do as many attempts as necessary to do the basic settings, sometimes it takes some time to it react. Be patient with that.
Start over each indicated process when you do not get the results.
- Exit from ABS unit, enter again, writes the security access (again), basic settings etc...
When everything is OK:
Inflate the tires to the correct pressure and check the tire pressure monitoring. (user manual)
Good luck for tomorrow!
