Polo 6R ABS CODING
Drives: Polo 6R 1.2 TDI
Re: Polo 6R ABS CODING
Post by iichel » Fri May 22, 2020 6:10 pm
There is no factory option to match this configuration
theweekendmech
Drives: Polo GT TSI 1.2
Post by theweekendmech » Fri May 22, 2020 7:19 pm
Can I run the 310 front and rear disc coding for now? What would be better? Run it on the current coding or switch to either a 288 front and drum rear coding or 310 front plus rear disc coding?
Post by iichel » Fri May 22, 2020 7:33 pm
I'd suggest to code it to 288mm fronts and 200mm rear drums. Adding discs will probably improve braking stability but unless you actually fit a WRC or GTI engine, you won't be able to code it to 310mm discs
theweekendmech
Post by theweekendmech » Fri May 22, 2020 10:52 pm
thanks a Ton for the suggestion iichel. Can you please give me the code thats gonna match my polo? I can barely find any working codes for indian spec polos
Post by iichel » Sat May 23, 2020 10:14 am
Sure thing
Could you please try just to enter these two codes to see if they are accepted?
62DD6863422703C5461B16714259C0800904 312mm + 232mm
62DD7863422703C5461B1E714259C0800904 312mm + 256mm
Suggestions for your car:
62DD4463422703C5461B22714259C0800904 288mm + drums (option 1)
62DD4863422703C5461B12714259C0800904 288mm + drums (option 2)
You can try the latter two codes, they both appear in the factory configuration of 288mm fronts and rear drums.
theweekendmech
Post by theweekendmech » Sat May 23, 2020 4:41 pm
Sure thing
Thanks for the codes. I tried all 4 codes. It threw the same error for all these codes
Coding Rejected : Error 31 : Request out of range
Post by iichel » Sat May 23, 2020 5:14 pm
Understood, I'll have a look later tonight.
Post by iichel » Sat May 23, 2020 8:47 pm
What happens if you change byte 2 to 48 and simultaneously change byte 10 to 12?
theweekendmech
Post by theweekendmech » Sat May 23, 2020 9:51 pm
It still gives me the same error. out of range.
Post by iichel » Sat May 23, 2020 9:53 pm
This is very strange. What version of VCDS are you using? Legal or clone?
theweekendmech
Post by theweekendmech » Sun May 24, 2020 1:23 pm
Im using the latest version that there on ross tech’s website. It is a legit unit that I am using. I tried putting in the basic setting security code and doing it too. Same results. Anything else that I should be doing but missed? Im new to this coding thing so might miss on some noob steps.
Last edited by theweekendmech on Sun May 24, 2020 1:26 pm, edited 1 time in total.
Post by iichel » Sun May 24, 2020 1:25 pm
Very interesting. I don't know how to solve this. Your coding as it is now appears to be correct. But somehow it does not accept any other brake diameter.
theweekendmech
Post by theweekendmech » Sun May 24, 2020 1:27 pm
Is there any other work around for such an issue?
Post by iichel » Sun May 24, 2020 2:39 pm
I don't really know.
It can come down to a couple of reasons:
- vcds bug
- some error in your abs module
- it is simply not possible to modify your coding
theweekendmech
Post by theweekendmech » Sun May 24, 2020 3:49 pm
So I tried putting in the security access code for the basic setting and it did accept but when I tried putting in the advanced code, it dint accept the code suggested by vcds. Anybody has any idea what code needs to be entered for the advanced security access?
