RNS 510 question
- Nlolotte
- Drives: Polo 1.2 R-Line TSI 6R
RNS 510 question
If i buy RNS 510 will navigation automatically show on my highline mfd or do i need to code it in?
- CNK
- Drives: 6R
Re: RNS 510 question
You need other instrument cluster (BlueGT or WRC or GTI)
- Nlolotte
i have the glut gt one already
Then you'll be fine
- Nlolotte
thank you! so plug and play no vcds?
- habib_123
- Drives: Polo 6R 2012 1.2TDI RHD
If you do install the RNS-510 you will need to code it into the car (VCDS). Go into CAN Gateway installation list and tick the box for navigation.
Once done go back out, and into navigation and check coding. I can provide mine if needed.
Good luck!
Good luck!
