Spacers & Springs
Posted: Tue Oct 25, 2016 2:38 pm
by Clint
I'm planning on putting 20mm back and 15mm front spacers on a 6C, are other people running similar spacers, especially anyone that is running with 35/55mm springs - any issues?
Other than fitting them, are there other things I should consider such as geting the wheels realigned, etc?
Cheers for the advice!
:D
Re: Spacers & Springs
Posted: Wed Oct 26, 2016 7:00 pm
by Spitsy
I'm currently using 15mm spacers on front and rear with 17x7J ET42 205/40/r17 without any problems. 20mm wouldn't be a problem either. It really depends on the rims you are using, which offset and width and stuff. However I'm a little bit higher then you. 35/45mm with Bilstein B14 coilovers. I personally think there is no need to re-align your wheels.
Hope this helps you a little bit :)
Posted: Thu Oct 27, 2016 6:23 pm
by Bigfish99
Thats with the 30/45 HR Springs in.... 10mm spacers front and 15mm rear!
No issues.... never got them realigned... didnt feel there was any need too runs perfect!
Posted: Mon Jan 23, 2017 8:37 am
by asafzabari
Bigfish99 wrote: Thats with the 30/45 HR Springs in.... 10mm spacers front and 15mm rear!
Did you had to replace the bolts on all wheels? or just the rear ?
Thanks.
