Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
Drives: Polo 6R 1.2 TDI
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
Post by iichel » Wed Mar 25, 2020 4:12 pm
Looks pretty neat to me. Is the brightness comparable to, i.e., the 12V socket in the centre console?
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf » Wed Mar 25, 2020 10:11 pm
Yes. i would guess its more or less around that brightness. maybe a bit more. But will see. i just test the light and door panel outside the car.
Drives: 9N3/6R Rline/G7.5/ⵣ Rline'19/T-Cr'20
Post by ciclo » Fri Mar 27, 2020 6:10 am
benzinkopf wrote:
Tue Mar 24, 2020 1:34 pm
:arrow: https://www.ebay.de/str/khteile
benzinkopf
Post by benzinkopf » Fri Mar 27, 2020 3:36 pm
Hooray. I’m lovin it. sorry ive to let the footwell light open as i need the light to capture this. Image1x led in each door. now will try to do the same shade to the centre and all footwells with another 6x leds.
Post by iichel » Fri Mar 27, 2020 5:32 pm
Looks great, very nice.
RobertVW
Drives: T6
Post by RobertVW » Fri Mar 27, 2020 5:57 pm
Well done mate!
benzinkopf
Post by benzinkopf » Sat Mar 28, 2020 3:12 pm
Hehe. too bad i competed the solutionImage. btw my friend, i’m currently testing out the ambient light position like you did near the arm rest pillar projected to the front dash. But it seems like with red led, it’s not really make any diff to the centre console except some reflection in my gear knob n the aluminium finish of the gear selector cover.
do you have any photo to show the effect with your white led in the same position? appreciate that. thanks.
Post by ciclo » Sun Mar 29, 2020 2:55 am
hi Amir, I took pictures, but as you already know, it is necessary to have a good photographic equipment (which I do not have) so that it captures the dim light emitted by the ambient lights that I installed.
These images ended up in the recycling bin. :P
I promise that the ambient light I installed on the center console (Armrest) does its job perfectly. Perfectly illuminates the parking/hand brake and adjacent gaps, it is not reflected at any point, so they do not disturb at all, rather the opposite, it helps the perception of space inside the cabin indirectly.
I have a very good feeling when driving with the ambient lights that I installed on my 6R (with our Golf MK7.5 the same).
It is a small change in the perception of the interior cabin that is very noticeable when driving other vehicles without these small ambient lights. 8)
benzinkopf
Post by benzinkopf » Sun Mar 29, 2020 3:14 am
Great. If thats the case, i will proceed installing around the same area. maybe if red is still no good, i will change to white also later. Thanks.
In addition to that, im thinking of placing another one from under the centre rear seat to illuminate the area behind my armrest, as it is practical to see the usb port and i do feel its too dark back there. still testing.
Post by ciclo » Mon Mar 30, 2020 4:49 am
It is a good idea, maybe the red led for the test that you are using in the previous image is too powerful.
IMHO ambient lights with a practical sense (not an aesthetic sense) should be very dim.
benzinkopf
Post by benzinkopf » Mon Mar 30, 2020 3:00 pm
Oh yes. you are right. I was testing the light distribution directly from the led without any cover lens. Just to see the light up area in that position. Surely will reduce the brightness with some lens later then i wont be able to capture the light anymore.
benzinkopf
Post by benzinkopf » Mon Mar 30, 2020 3:11 pm
now trying to make a cover for this “unfinished” foot vent Image
Post by iichel » Mon Mar 30, 2020 3:19 pm
You should make your OBD2 connection there :mrgreen:
benzinkopf
Post by benzinkopf » Mon Mar 30, 2020 3:33 pm
good idea iichel!hehe. or maybe i can block off that vent, and make a nice adaptor there with some fragrance, so if i feel like want to make the car smells good, ill just turn to foot vents
