UK-POLOS.NET - THE VW Polo Forum • Hardwire dashcam install Polo 6R/6C DIY
Posted: Sat Nov 26, 2016 9:29 pm
by 6RPotentialBuyer
Just thought I'd post a guide on how to hardwire your dashcam into your Polo. I'm not a professional in anyway I just followed a few YouTube videos. It has worked very well for me and since the install I have had no issues :D
Here's what you need.
12V to 5V USB converter
"Add a fuse" or "Piggy back fuse" (Same thing)
Crimp connectors and crimping tool or soldering iron.
Dashcam and a long power cable.
This is what the wired set up looks like with all parts.
You plug the USB into the USB for the dashcam. The red wire is connected to the "Add a Fuse" and the black wire is grounded. I connected mine to a screw.
Here's what mine looks like. (Sorry for the rubbish images)
Plug the add a fuse into the fusebox under the steering wheel. I plugged mine into the "rear window wiper motor" fuse (This fuse works with the ignition, so when you turn the key the camera automatically starts recording, and when you turn the car off it stops recording and turns off). A list of all fuses can be found here http://www.team-bhp.com/forum/attachmen ... -fuses.pdf
I grounded it to this screw. I tucked the converter and excess wiring here because it is out of sight.
Now you need to run the wiring up. I put mine up the rubber seal the runs along the side of the car. The cable doesn't get crushed here and it is always out of sight.
This is a diagram of where I ran my wire. (Wire in red) It just goes up the rubber real and then goes across the A pillar (Just needs to be pulled lightly and tucked under, no need to pull it off) it's then tucked under the headliner and goes to my dashcam.
This is what the wire looks like coming from the headliner.
I mounted my dashcam onto the rearview mirror. I didn't want to have a suction cup mount because they are quite bulky. This is also a good location for the video recorded on the dashcam.
This is what my dashcam looks like from the outside (The flash makes it look more obvious than it is)
Overall I'm really happy with how this turned out. It works flawlessly and it is a nice and discreet install. Instead of paying halfords £50 to fit it, I did it for £5 :D
Re: Hardwire dashcam install Polo 6R/6C DIY
Posted: Sun Nov 27, 2016 9:34 am
by derkie54
Good post and nothing wrong with the photo's. :)
Posted: Sun Nov 27, 2016 11:31 am
by Bigtam
That's pretty much how I done mine apart from the fuse position
Posted: Sat Jun 10, 2017 6:41 pm
by lebjos
I just bought one that plugs directly into the OBD port, it's always recording if it senses motion, even with the engine off.
Posted: Fri Jun 30, 2017 9:30 pm
by atj_allstar
Thank you for the detailed pics of dashcam install. I was able to install it and route the hardwiring similar way in my Polo 6R RHD version. Only difference i made is change in the fuse tap as i used fuse 12 and also I found a better ground point which is a nut attached to the frame of the car after opening the panel on the extreme right side of dashboard (RHD car). Image https://www.dropbox.com/s/gh6zx4ze9zmnt ... d.jpg?dl=0
I have loosen the nut above and connected the ground there. Sorry no picture after installation.
Posted: Thu Aug 31, 2017 4:15 pm
by snudge
Hi, I'm in the process of hardwiring my dashcam but I am struggling to find the ground point that you have shown in your picture. Can you please tell me where this is located?
Thanks.
Posted: Tue Sep 12, 2017 4:47 am
by 6RPotentialBuyer
snudge wrote: Thu Aug 31, 2017 4:15 pm Hi, I'm in the process of hardwiring my dashcam but I am struggling to find the ground point that you have shown in your picture. Can you please tell me where this is located?
Thanks.
Apologies for the late reply, I haven't been very active on the forum lately haha. That ground lis located just next to the pedals. I'll take a better quality picture of it in the morning :)
Posted: Wed Aug 29, 2018 10:37 pm
by LoveOfPolo
6RPotentialBuyer wrote: Sat Nov 26, 2016 9:29 pm Just thought I'd post a guide on how to hardwire your dashcam into your Polo. I'm not a professional in anyway I just followed a few YouTube videos. It has worked very well for me and since the install I have had no issues :D
HI!
Can you please send me the pics again because they're all down use imgur.com or attach them directly to the forum please.
Posted: Sat Sep 21, 2019 10:25 pm
by j3rom3
Posted: Tue Mar 10, 2020 11:50 am
by EvanZA
Thanks for this post. Im planning on doing the same :wink:
