Help Please DRL's from Headlight to lower aux fog assembly
Posted: Wed Feb 08, 2017 9:33 pm
Could someone help me please ?
We own a 62 plate 6R polo with DRL's fitted to the main head lamp unit, and I would like to fit an aftermarket / OEM fog lamp with DRL's.
The lamp is available for my model car, but what I need to know is what wire do I pull off from the headlamp unit to power up a DRL bulb fitted into the replacement fog lamp.
The car came with factory fog lamps with turn light,
The problem I get is when I go over speed humps, on coming traffic think I'm flashing them to proceed, and it is leading to so much frustration, I know it is just as easy to use the side light / main light switch, but I prefer to jump in the car and drive and turn on the main lights when it is dark, not worrying about turning a switch to cancel the drl's
So if there is help out there it would be appreciated
Cheers Paul
Cheers Paul
