256mm rear brake upgrade Polo 6r GTI Mex HELP!!
Posted: Thu Feb 09, 2017 5:42 am
Hello mates, my name is Roberto I would like to share with you my rear brake upgrade
I have been doing some research and finally put together all the stuff needed to do the upgrade:
Discs
Calipers and carriers
Pads
Spash shields
I will share the part numbers in a while, I've already done the conversion but I have some concern about the torque settings of this elements:
Does somebody know the torque setting for those 4 bolts holding the splash plate to the axle?? and also the torque for the 12 point nut to hold the hub into the stub axle?
I will make a step by step guide as soon as I finish.
Thanks in advance
Roberto
Discs
Pads
Spash shields
Thanks in advance
Roberto
