UPGRADING BCM 6R
govindsharma
- Drives: polo 1.2 petrol HighLine
UPGRADING BCM 6R
Dear Ciclo I had open new topic as per your instruction.Now Kindly help me for following retrofits.
1. BCM to MAX ( 7E0 937 090)
2. I want to install bi xenon lights but in future.
3. AFS.
4. Upgrade the headlight wiring to enable BCM to control the headlights
5. IF possible High beam assist with stalk also.
Dear I had purchased new instrument cluster but not reached to me.keep this in mind i will also want to install it VW person said that they will help me for this.Sir please tell me what other thing i have to inform you.
Saturday,24,December,2016,08:55:23:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3
Data version: 20161010 DS255
http://www.Ross-Tech.com
VIN: MEXD16603GTXXXXXX License Plate: 24122016
Mileage: 1350km-838mi Repair Order:
Chassis Type: 60 (6RU)
Scan: 01 03 08 09 10 15 17 19 25 44 56
VIN: MEXD16603GT082427 Mileage: 1350km-838miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CJLA) Labels: None
Part No SW: 03E 906 019 AQ HW: 03E 906 019 AQ
Component: SIMOS11.2 H04 1968
Revision: --H04--- Serial number:
Coding: 00110016032400000000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12MPI02103E906019AQ 001001
ROD: N/A
VCID: 73E5B5AADA7402DAAD-8026
No ASAM data for: "EV_ECM12MPI02103E906019AQ" (VW25)
Readiness: 0000 0100
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 BP HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0003
Serial number: --------------
Coding: 60DD2763212B18C20618E46B845818000000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 0D11C352DC90742ADB-8058
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41892F62D848E04AEF-8014
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6RU 937 086 M HW: 6RU 937 086
Component: BCM IM M+4 H40 0432
Revision: BY040001 Serial number: 0200 078160167
Coding: 3AB02BFF48A30000013800006D0B169000C0414F60AC0000200000000000
Shop #: WSC 01070 002 104857
VCID: 6BD5ADCA8A44DA1A65-803E
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 311215 03 37 0059
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 020 2551
Serial number: 13202848160111221608
Coding: 350000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 020 2551
Serial number: 13202849160107223746
Coding: 040000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 0111607164000748AB2B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 019 1552
Serial number: 13102728160108150857
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 019 1552
Serial number: 13202729160111111032
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 35821404004439
Coding: 308001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K.rod
VCID: 3A7B588EBD9EB392AE-806E
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW013KE03
Coding: 003036
VCID: 49993742E878280A37-801C
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6RF 920 861 B HW: 6RF 920 861 B
Component: KOMBI H01 0215
Coding: 1108000000
Shop #: WSC 12345 123 08192
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 4A9B084EED7E23123E-801E
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 086
Component: GW-K-CAN TP20 H40 0432
Revision: BY040001
Coding: 002200
VCID: 1939A7021058988A47-804C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H01 0215
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADBA8CE8DBEC3121E-803E
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_VW12.rod
VCID: 41892F62D048E04AEF-8014
Address 56: Radio (J503) Labels: User\6RF-035-187.clb
Part No SW: 6RF 035 187 HW: 6RF 035 187
Component: Radio 013 0116
Revision: -------- Serial number: VWZGZ1S0840292
Coding: 00000440000002
VCID: 0603FC7EB1E607729A-8052
End-------------------------(Elapsed Time: 02:23)--------------------------
3. AFS.
ROD: N/A
Revision: V0000000
Coding: 0728DD
Coding: 350000
Coding: 040000
Coding: 240000
Coding: 308001
Coding: 003036
Coding: 1108000000
Revision: BY040001
Coding: 002200
Serial number:
Re: UPGRADING BCM 6R
Thanks for letting me know by PM about your new topic. Yesterday I was reviewing your autoscan.
Please can you post here the following pics from your 6R?
Relay carrier
Light Switch connector
Dimmer connector
Fuse box
From Light Switch and Dimmer connectors I need to see the wires colors and slot positions. In the graaja's topic you can see several examples of the pics I need.
Here too
Take also some pics from your 6R (front, rear, dashboard - stalks, MFSW, IC, radio -). More info = better help.
Thanks.
Relay carrier
Dimmer connector
Fuse box
Thanks.
govindsharma
Dear These are the pics of my car parts that you need kindly check it
I think it will be feasible. You'll need:
a wiring loom,
bcm,
stalks,
Light switch
Mirror interior for hba
Did you already buy anything?
a wiring loom,
bcm,
stalks,
Light switch
govindsharma
No, Only BCM max and MFA+ i had ordered and it is on the way.Can you tell me other required part no and availability in market.
Thanks for the pictures.
You do not need to buy another AUTO light switch, the one you currently have with Auto function is correct.
Well, everything is under study. I will manufacture the wiring for your 7E0 937 090 BCM Max adaptation, also those related to HBA system and therefore for automatic lights OEM. The HBA system depends on the automatic lights.
If you want the wiring for the HBA system it is necessary to wait until the instrument cluster with MFA+ is installed and working perfectly. If you do not want HBA, I can start making your wiring for BCM Max adaptation and Automatic lights.
Please tell me how your static cornering lights work. (fog lights)
- with the indicators.
- when turning the steering wheel.
- with the indicators and when turning the steering wheel.
govindsharma
Sir I think it is with indicator because when i round steering wheel to right and give left indicator left fog light glows and vice versa.
Can we make it with steering ? with your wiring loom.
I think that requires adding a steering angle sensor to your stalks.
It's a bit more complicated.govindsharma wrote:Sir I think it is with indicator because when i round steering wheel to right and give left indicator left fog light glows and vice versa.
Your 6R has ABS unit, and in the 6R the steering angle sensor is associated with the Brakes unit. If you do not have ESP unit you can not install a steering angle sensor. But, I'm not totally sure, maybe firegrafik can enlighten us about it, it is possible that in the russian forum http://www.Drive2.ru or .com you can find more information about it. They have made many modifications with ABS units.
So, the static cornering lights funtions for your future Bixenon headlights would be limited to the indicators only. As it is currently.
For these and other reasons I request the pics from your 6R, it is not due to personal whims.
Please, show us your current headlights and dashboard, similar to these: (graaja's GT)
http://www.team-bhp.com/forum/attachmen ... ront-2.jpg
http://www.team-bhp.com/forum/attachmen ... onsole.jpg
http://www.team-bhp.com/forum/attachmen ... -wheel.jpg
http://www.team-bhp.com/forum/attachmen ... switch.jpg
This will make my work 1000000% easier, with them I can also see what you have done on your GT to make better wiring.
You have to keep in mind that I only have one chance to make your wiring correctly, it is not possible any other circumstance... so I can not make any assumptions.
My wiring are customized to the car in question and the requiements requested.
govindsharma
Sir Car Images that you required.
govindsharma
Excellent pics. Thank you very much.
This week I'll make your wiring. (as soon as possible)
Please tell me what you want (here is the sale of my looms):
B -> wiring for BCM adaptation and wiring for Automatic Lights + CH/LH, etc... = 135€ + shipping costs.
C -> wiring for BCM adaptation, wiring for Automatic Lights + CH/LH, etc..., and wiring to be able to install and make work the HBA system = 160€ + shipping costs.
Shipping cost from Spain to India = 24€ (500gr - 1Kg)
Notes (info):
- When you install my wiring everything will work correctly with your new BCM, regardless of the equipment you install later.
- If you choose B, in the future you can not install the HBA system with these wiring looms. I make these wiring looms (B) for those who do not want HBA and want to install Bixenon or LED headlights (depending on the BCM model).
- If you want to install Bixenon headlights you will have to buy the harness from T10 to T14 headlights connectors. And maybe a new wiring for your fog lights to transfer the static cornering lights from the fog lights to the Bixenon headlights (depends on your decision).
- Also, If you want the two necessary wires (CAN Lines - 2 meters) with the correct terminals for HBA system that go from T8 connector (mirror with camera) up to the terminals ready for HBA in my adaptation wiring you have to add 10 euros to the total cost.
I think your mirror has a T8 connector, not specified in ETKA
, on previous dates it was T6.
The mirror with camera for HBA uses the T8 connector.
Notes (info):
govindsharma
Dear My car has 3G0857511 E interior mirror and i think mirror with camera is essential for HBA.
Sir I want to purchase C wiring with HBA.(C- Automatic Lights + CH/LH + Light Assist. Wiring)
which part i have to purchase for HBA and AFS can you please tell me.
Dear if in future i will purchase bi xenon lights can these wire is compatible because my next aim is to upgrade my car headlights. or can you make wire bi xenon compatible.
My car interior rearview mirror image.
graaja
- Drives: Polo GT TSi
Hi govindsharma,
I have a doubt. Did your Polo come with automatic headlights? Or did you install the retrofit auto headlight switch which has its own light sensor?
