Upgrade to BCM Max with RLS and auto headlight (Dual beam H7)
antardaksh04
Drives: TSI
Re: Upgrade to BCM Max with RLS and auto headlight (Dual beam H7)
Post by antardaksh04 » Fri Jun 23, 2017 8:28 pm
Thanks graaja,
Hi ciclo,
Yes I will definitely reach out to you for help. I wanted to complete parking sensors install first, since this was pending in stages from past 6 months.
Regards.
Gauravshivdas
Drives: Polo 6R 1.5 TDi Highline
Post by Gauravshivdas » Thu Jun 29, 2017 8:54 am
ciclo wrote:+1
Good job! 8)
You already know that you can contact me by email if you need my help to install the BCM adaptation wiring and automatic lights. :wink:
Hi i’m also planning to use the RLS oem fitment for activating auto headlights function! The car comes with rain sensing function provided by company, but the headlights are manually operated. What kind of wiring i will need for activating the auto headlights function?
govindsharma
Drives: polo 1.2 petrol HighLine
Post by govindsharma » Thu Jun 29, 2017 4:07 pm
Dear I had also activated auto headlight with OEM RLS with the help of Ciclo Sir,You may read this topic for better knowledge .
viewtopic.php?f=56&t=69603
Drives: Polo 6R '13 / Golf MK7.5 '19
Post by ciclo » Thu Aug 17, 2017 10:29 pm
Hi ciclo,
Regards.
Image... :lol:
Best regards :wink:
antardaksh04
Drives: TSI
Post by antardaksh04 » Thu Aug 24, 2017 7:11 pm
Hi Ciclo,
Thanks for the reminder, I started installation of wiring however I wasn't able to complete this in a single day. I have managed to install all the wires in BCM connectors and planing to complete remaining work tomorrow.
As mentioned by several folks connecting wires to the BCM connectors is the toughest part. I spent two days (2 hours each) making all connection to the BCM.
I will use the code shared by you and will reach out to you in case I come across any issue.
Regards.
Post by ciclo » Fri Aug 25, 2017 6:12 am
I understand you perfectly, I wish I could help you to do it ...
Please, post a Autoscan with the results in any case. Thanks
antardaksh04
Drives: TSI
Post by antardaksh04 » Tue Aug 29, 2017 8:14 am
I finally completed major part of this install. The only part remaining is connection of license plate wire to the point indicated in the guide. Hence you will notice error for the same in VCDS scan.
I would like to thank Ciclo for his help in this installation, right from guiding me with the questions to preparing wiring.
I will try to provide brief summary of the install and final result.
I opted for the following wiring
B- Wiring for BCM Max adaptation + Automatic Lights Wiring + CH/LH.*
For those with a BCM from factory 6R093708X. X=5/6/7.
You need a BCM Max (7H0 or 7E0), Light Switch AUTO, Rain Light Sensor.
I completed this install in phases
1. Installed Auto dimming mirror.
2. Completed wiring for RLS.
3. Installed DRL beside foglight, I did this along with wiring for front OPS.
4. Installed BCM Max
5. Installed wiring provided by Ciclo
6. VCDS coding.
After installing everything I found that headlight was not working. I took help from Ciclo and found that the relay bridge was not installed in the correct place. Installing relay bridge in right place fixed the issue.
Foglight with DRL (non OEM)
BCM 7E0 937 090 PQ25 Max4 H80 0733
OEM Auto dimming IRVM (inside)
Auto dimming IRVM (outside)
Auto headlight Switch and Dimmer with range controller
Dimer Switch
DRL beside foglight
DRL off with blinker
VCDS scan with two errors (license plate light and speakers)
VIN: XXXXXXXXXXXXXXX   License Plate: 101029AUG2017
Mileage: 9140km-5679mi   Repair Order: 101029AUG2017
Chassis Type: 60 (7E0)
Scan: 01 02 03 08 09 10 15 17 19 25 44 56
VIN: XXXXXXXXXXXXXXX   Mileage: 9140km-5679miles
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number:
   Coding: 00250056232400080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12TFS02013F906070KC 004006
   ROD: N/A
   VCID: 6DD6519BBC82595686-8038
No ASAM data for: "EV_ECM12TFS02013F906070KC" (VN75)
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6501
   Revision: 00043014    Serial number: CU501507096691
   Coding: 0000020
   Shop #: WSC 01324 785 00200
   VCID: 3A7CAAC7754C3EEE53-806E
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 BN    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2C63422607C24615346E4253E0800908
   ASAM Dataset: EV_Brake1ESP90bIOSCH 003031
   ROD: N/A
   VCID: 0B123F03A256F76638-805E
No ASAM data for: "EV_Brake1ESP90bIOSCH" (VW26)
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 418EDD2BD89A6D3612-8014
Address 09: Cent. Elect. (J519)       Labels: User\7H0-937-08x-09.clb
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 316150356
   Coding: 3A984BBF48A10000013006B07CCB96985FC0616F608C20C1200000030000
   Shop #: WSC 12345 123 12345
   VCID: 68D8208F9B607C7EF5-803C
   Subsystem 1 - Part No: 5K7 955 559 C
   Component: RLS 020816 04  42  0106
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 802 AL    HW: 6R0 959 802 AL  Labels: 6R0-959-802.CLB
   Component: -------------  006 5520
   Coding: 010000
   Subsystem 3 - Part No SW: 6R0 959 801 AH    HW: 6R0 959 801 AH
   Coding: 010000
   Subsystem 4 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Coding: 020000
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 249
                    Mileage: 9140 km
                    Time Indication: 0
                    Date: 2015.12.10
                    Time: 08:50:33
Address 10: Park/Steer Assist        Labels: None
   Revision:     Serial number: 0105
   ASAM Dataset:  Unknown
   ROD: N/A
   VCID: 55A6197B3412F1965E-8000
No ASAM data for: "" (VN75)
   Revision: --------    Serial number: 003GW00ZT3G5
   Coding: 003036
   ASAM Dataset: EV_AirbaVW01BPAVW250 A01001
   ROD: N/A
   VCID: 499EC50BE8AAA576CA-801C
No ASAM data for: "EV_AirbaVW01BPAVW250" (VW26)
   Part No SW: 6RF 920 861     HW: 6RF 920 861
   Component: KOMBI         H01 0214
   Coding: 140800
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 0818000FB3209C7E15-805C
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 002300
   Component: IMMO          H01 0214
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6ADC5A878D6C4E6EE3-803E
Address 44: Steering Assist (J500)       Labels: 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_SE12.rod
   VCID: 418EDD2BD09A6D3612-8014
Address 56: Radio (J503)       Labels: 6RD-035-187.clb
   Part No SW: 6RD 035 187     HW: 6RD 035 187
   Component: Radio         517 5124
   Revision: RB101000    Serial number: VWZZZ4Q5030993
   Coding: 00000440040001
   Shop #: WSC 00078 790 00236
   VCID: 0400143F8708B81E79-8050
2 Faults Found:
00870 - Bass Speaker Front Left (R21)
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 9140 km
                    Time Indication: 0
                    Date: 2015.12.10
                    Time: 09:00:52
00872 - Bass Speaker Rear Left (R15)
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 9140 km
                    Time Indication: 0
                    Date: 2015.12.10
                    Time: 09:00:52
End-------------------------(Elapsed Time: 02:49)--------------------------
I capture video of dimmer
I would also like to thank firegrafik and other forum members who have shared valuable information in this and other forums.
Regards.
Last edited by antardaksh04 on Tue Aug 29, 2017 12:21 pm, edited 3 times in total.
Post by ciclo » Tue Aug 29, 2017 8:32 am
Thanks for this report. 8)
Fault of license plate lights can be eliminated by coding, but it is best that you complete the installation, it's very easy.
This way you will be warned when these lights have faults. Better for you.
Let your BCM MAX do its work.
I am at your disposal. :wink:
antardaksh04
Drives: TSI
Post by antardaksh04 » Tue Aug 29, 2017 8:36 am
Hi Ciclo,
Thanks, I will complete wiring for license plate light this weekend. Its already connected to BCM and the only part pending is connection near light in boot.
Regards.
Post by ciclo » Tue Aug 29, 2017 9:32 am
Great! :wink:
In the previous report I have seen that it rains in the area where you live. Please take a week to observe the operation of the automatic lights, LH and many other functions to inform about the sensitivity of the light sensor.
Maybe at first you notice it too sensitive, but I can assure you that it works exactly when it should do so.
The 5K7 light sensor models are somewhat better managed than the previous 1K0 models.
antardaksh04
Drives: TSI
Post by antardaksh04 » Fri Sep 01, 2017 8:47 am
Hi Ciclo,
Everything seems to be working fine, however I noticed that rain closing of windows is not working. I tried with car locked/unlocked.
I haven't checked coding with VCDS after the install. I just copied/pasted code provided by you.
I will check if I need to enable this in VCDS.
Regards.
antardaksh04
Drives: TSI
Post by antardaksh04 » Mon Sep 04, 2017 1:30 pm
This issue is resolved. Rain closing was not working because after disconnection of battery I did not set one touch open/close of windows.
Regards.
Post by ciclo » Mon Sep 11, 2017 5:59 am
Regards.
:wink:
This is a very interesting data regarding window regulator motors on un VENTO/POLO 6R IND 2015. (comfort function)
Post by ciclo » Sun Oct 14, 2018 4:27 am
October,2018
The problem that you mention to me by email is related to the light sensor wires. Check the fuse and RLS wires, one of them does not make a good contact or is loose. (intermitent fault)
Saturday,13,October,2018,22:23:59:05031
VCDS Version: 15.7.1.0
Data version: 20150904
www.Ross-Tech.com
VIN: MEXJ15608GT032152   License Plate:
VIN: MEXJ15608GT032152   Mileage: 12560km-7804miles
   ASAM Dataset: EV_ECM12TFS02130F906070KC 004006
   ROD: N/A
No ASAM data for: "EV_ECM12TFS02130F906070KC" (VN75)
   Coding: 0000020
   ASAM Dataset: EV_Brake1ESP90iOBSCH 003031
   ROD: N/A
No ASAM data for: "EV_Brake1ESP90iOBSCH" (VW26)
   Revision: V0000000
   Coding: 3A984BBF48A10000013006B07CCB96985FC0616F608C2041200000030000
   Component: RLS 042  42  0106
   Coding: 0714DD
   Coding: 010000
   Coding: 010000
   Coding: 020000
   Coding: 020000
2 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
            014 - Defective - Intermittent
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 89
                    Mileage: 12565 km
                    Time Indication: 0
                    Date: 2017.01.23
                    Time: 22:21:30
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 49
                    Mileage: 12565 km
                    Time Indication: 0
                    Date: 2017.01.23
                    Time: 22:09:16
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261224902578
   Coding: 108101
   Shop #: WSC 02756 790 50316
   ROD: EV_VW75XParkAssis8K_VN75.rod
   VCID: 397EB5CBB84A35F65A-806C
Address 15: Airbags (J264)       Labels: None
   Part No SW: 6R5 959 655 O    HW: 6R5 959 655 O
   Component: VW40AirbabU06 H10 0025
   Revision: --(-----    Serial number: 006GW00ZT6G5
   Coding: 003036
   Shop #: WSC 01234 401 00200
   ASAM Dataset: EVZAirbaVR10BPVAR250 A04001
   ROD: N/A
   VCID: 53A2E7633AE6EFA6B0-8006
No ASAM data for: "EVZAirbaVR10BPVAR250" (VW26)
   Coding: 140800
   Revision: B9080001
   Coding: 002300
   Serial number:
   ASAM Dataset: EV_SteerAssisNKS 014008
   ROD: N/A
No ASAM data for: "EV_SteerAssisNKS" (VW12)
   Coding: 00000400040001
3 Faults Found:
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 49
                    Mileage: 12565 km
                    Time Indication: 0
                    Date: 2017.01.23
                    Time: 22:19:02
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 49
                    Mileage: 12565 km
                    Time Indication: 0
                    Date: 2017.01.23
                    Time: 22:19:02
00876 - Treble Speaker Rear Left (R14)
            011 - Open Circuit - Intermittent
                    Fault Status: 00111011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 49
                    Mileage: 12565 km
                    Time Indication: 0
                    Date: 2017.01.23
                    Time: 22:19:02
End-------------------------(Elapsed Time: 02:43)--------------------------
Fault Priority: 2
Fault Frequency: 3
Reset counter: 89
Mileage: 12565 km
Time Indication: 0
Date: 2017.01.23
Time: 22:21:30
I remember that I didn't sell you the RLS wires... where did you buy the RLS wiring/wires? Do you remember which is the fuse where you connected the power for RLS?
Something happened during the yearly service at your VW dealer or at another time... (this is not important, the important thing is to solve the problem)
The BCM codings are correct in both cases. (from me and from VW dealer)
By the way, if you are not going to install the wire for license plate lights, you can use the following BCM coding and you will avoid the fault for license plate lights in the autoscan.
3A984BBF48A10000013006B07CCB96985FC0616F608C2041200000020000
Please tell me the result.
Please, please, please, write here in your dedicated topic whatever you need from me, I no longer provide technical support by email or private message to anyone.
Thank you very much x1000.
antardaksh04
Drives: TSI
Post by antardaksh04 » Tue Nov 20, 2018 6:56 am
I was able to fix this issue with help from Vento2013. He had a similar problem after periodic service with same error code.
Following is the fix to solve this issue.
1. Remove/connect negative terminal.
2. Clear all error codes
Auto headlight and wiper is working as expected.
However I am not sure why DRL does not turn off while using indicator (blinker) as it was working earlier.
   Coding: 0714DD
   Coding: 010000
   Coding: 010000
   Coding: 020000
   Coding: 020000
1 Fault Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 71
                    Mileage: 12706 km
                    Time Indication: 0
                    Date: 2017.03.02
                    Time: 10:53:02
