Linking footwell lights to headlight switch
JammyLuke
Drives: 2011 1.4 Polo SEL
Post by JammyLuke »
Hi, I'm wondering if it's possible to link the footwell lights, that come on when the doors are open, to the headlight switch. So when I turn the headlights on, the footwell lights come on, is this possible?
Thanks for any help!
Re: Linking footwell lights to headlight switch
Yes, should be possible. Just connect the positive wire of the footwell lights to the headlight switch wire for the headlight setting.
Of course a fuse should be in the setup, and a relay might be advisable. But possible, for sure.
iichel wrote: Wed May 17, 2017 7:55 am ... Just connect the positive wire of the footwell lights to the headlight switch wire for the headlight setting....
It may not close the circuit to ground through pin T73a/4, and if this were possible, the dome lights will also turn on. :|
I think it would be better to use new additional lights (ambient lights-LED) managed by a relay (activated with the signal from light switch or BCM).
I think I remember (not sure) that some user/guys in the German forum (polo6Rfreunde) managed to do this with an external module for original footwell lights. (white/red) http://www.passatplus.de/umbauteile/leu ... uchten.htm
Ricmondo
Drives: Polo Blue GT
Post by Ricmondo »
I'm curious, why do you want to link the footwell lights to the headlamps. It might be obvious but I'm puzzled ( put it down to old age!).
Ricmondo wrote: Thu May 18, 2017 8:07 pm I'm curious, why do you want to link the footwell lights to the headlamps. It might be obvious but I'm puzzled ( put it down to old age!).
Hi Ricmondo, I think what he is trying to achieve is something like in this video:
Dave_C
Drives: 1.2TSi Match
Post by Dave_C »
What video?
Ricmondo
Post by Ricmondo »
If you had feet like mine the last thing you would want to do is light them up but if it makes people happy that's good.
I'm still bemused but that's not unusual!
Interior plants also create a good atmosphere. :lol:
Dave_C
Post by Dave_C »
iichel wrote: Fri May 19, 2017 10:41 am click
Many thanks!
