Everything went relatively smooth till the end where we encountered problem with the control of the Sport Select button.
Hoping to find someone who can help here.
Details on the retrofitting process can be found http://jimmy-cbx.blogspot.sg/2017/05/po ... assis.html
Monday,08,May,2017,17:50:50:24118
VCDS Version: 17.1.3.0
Data version: 20170320 DS267.7
www.Ross-Tech.com
Dealer/Shop Name: cbx auto
Workshop Code: 305 91777 091777
VIN: WVWZZZ6RZFU049836 License Plate: POLO LEOW 1,2 DCC AFTER ERROR
Mileage: 25628km-15924mi Repair Order:
Chassis Type: 6R (6C0)
Scan: 01 02 03 08 09 14 15 17 19 44 5F
VIN: WVWZZZ6RZFU049836 Mileage: 25628km-15924miles
14-Susp. Elect. -- Status: OK 0000
5F-Information Electr. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CJZC) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 BB HW: 04E 907 309 AF
Component: 1.2l R4 TSI H21 8228
Revision: R5H21---
Coding: 01250012230411080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TFS01104E906027BB 001006
ROD: EV_ECM12TFS01104E906027BB.rod
VCID: 65CB5EAE643FF0697A-8030
CAN Converter 01:
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 046 G HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 5206
Revision: 00043014 Serial number: CU501409196312
Coding: 0014
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021.rod
VCID: 3E79D1C2A12983B1DB-806A
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 HW: 6R0 907 379 BA
Component: ESP9.0i H03 0002
Serial number: 08506045140922
Coding: 23DD2885892733C9111C106C0057C41491CC88080005C7090000
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 6CDD2B8A87D5C12125-8038
1 Faults Found:
1219 - Coding invalid
U10DA 00 [009] - -
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 155
Mileage: 25628 km
Date: 2017.05.07
Time: 17:39:07
Address 08: Auto HVAC (J255) Labels: 6C0-907-044.clb
Part No SW: 6C0 907 044 A HW: 6C0 907 044 A
Component: Climatronic H02 0104
Serial number: 1409101A-0029
Coding: 200020011001100001
ASAM Dataset: EV_ACClimaValeoPQ26 003001
ROD: EV_ACClimaValeoPQ26_VW26.rod
VCID: 224105B23591C751DF-8076
Address 09: Cent. Elect. (J519) Labels: 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 A HW: 6C0 937 089
Component: BCM PQ26 Hi4R H06 0047
Serial number: 001028001732
Coding: 03001840425300DB4B844000402703881000580253010000000000000000
Shop #: WSC 91777 305 91777
ASAM Dataset: EV_BCMA0 004003
ROD: EV_BCMA0_004_VW26.rod
VCID: 2E59E182714973314B-807A
Drivers Door Control Module:
Subsystem 1 - Part No SW: 6R0 959 802 CH HW: 6R0 959 801 CF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 9610
Serial number: KU0KU025091442688034
Coding: 1400A1
Front Passengers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 801 CF HW: 6R0 959 802 CH Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 9610
Serial number: KU0KU015091442581170
Coding: 0400A1
Relative Air Humidity Interior Sender:
Drivers Door Rear Control Module:
Subsystem 4 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8610
Serial number: KU0KU016091442593683
Coding: 1400A0
Passengers Rear Door Control Module:
Subsystem 5 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8610
Serial number: KU0KU020101442934135
Coding: 0400A0
Address 14: Susp. Elect. (J250) Labels: 6C0-907-359.clb
Part No SW: 6C0 907 359 HW: 6C0 907 359
Component: DAEMPFUNGS-SG H04 0007
Serial number: 13061602000033
Coding: 80
ASAM Dataset: EV_SwitcDampeContiTemic 001004
ROD: EV_SwitcDampeContiTemic.rod
VCID: 6AD12D928D21DF1157-803E
Address 15: Airbags (J234) Labels: 6C0-959-655.clb
Part No SW: 6C0 959 655 B HW: 6C0 959 655 B
Component: VW20Airbag01D 001 0330
Revision: -------- Serial number: 003LN000ZYH4
Coding: 88CCC000000000005C0000CA008800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3261F5F2657157D12F-8066
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 410 821 408 14
Component: SideSensor_Df 151 0800
Serial number: 3575H009F1627C1271FT
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 410 821 408 14
Component: SideSensor_Pf 151 0800
Serial number: 3585H00BF1628C01A09R
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 442 152 709 14
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00A31730323909X
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 442 152 709 14
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00A5176F6017144
Coding: 2D2D2D
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 6C0 920 730 A HW: 6C0 920 730 A
Component: KOMBI 110 0260
Coding: 2724090820000008000808000000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009036
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 1F470C4606E3EAB9F0-804A
Address 19: CAN Gateway (J533) Labels: 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H06 0047
Revision: -------- Serial number: 001028001732
Coding: 030100046F0A560071000000000000010001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_VW26.rod
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H04 0019
Serial number: 2561420373502242AB1B
Coding: 240000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 51281E41142821930261
1 Fault Found:
131699 - Control unit for information electronics 1
U1054 00 [009] - No Communication
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 25628 km
Date: 2017.05.07
Time: 00:12:49
Supply voltage: Terminal 30: 13.1 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 M HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3211
Serial number: CE9O0276
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 336FF0F69A6B5ED924-8066
Address 5F: Information Electr.
Cannot be reached
End---------------------(Elapsed Time: 02:43, Deb=2)-----------------------
