Rear tail light not working
Posted: Tue May 23, 2017 9:36 pm
The passenger side rear tail light doesn't work so I thought it was a dead bulb, so I went and got a new one today and it still doesn't work. The shop tested it and they discovered the bulb still works so I swapped it over with the driver side light and it worked fine. The brake lights are also fine.
Its obviously the electrical wiring that's causing it then but I'm not good at electrics, can someone explain how I might be able to fix it?
