Polo 6R Bosch ESP 9.0i ABS pump and control module
For sale, Polo 6R ABS pump and control module, for retrofitting ESP in Polo 6R, Vento, Fabia, Ibiza.
It is the ESP 9.0i from manufacturer Bosch, part number 6R0 907 379 AS, the successor of the ESP 8.2i system by Bosch.
Hardware version 0002 software version 0002
It is a nice upgrade from the ABS units, to provide Electronic Stability Control instead of Antilock Braking System.
It will require a coding of the ESP system, i.e. with VCDS. If you provide me with some data about your car, I can make the coding and send a pre-coded unit.
The information needed:
- vehicle VIN last 5 digits
- Engine code
- gearbox type (manual, DSG)
- chassis type (hatch, sedan)
- sizes of the front and rear brakes
After fitting, bleeding the brake system in necessary with a diagnostic tool (i.e. VCDS). Please take all necessary precautions and follow VW instructions when installing parts of the brake system.
Also you need to adapt steering angle sensor G85.
It is mandatory to take into account all the safety warnings when working on the brake system.
Price for the unit is EUR 100. Additional shipping fees apply.
For speed and cost saving, I can ship it from Germany.
  • Note!
For ESP systems, the steering angle sensor G85 is mandatory.
You have the steering angle sensor when:
- Static cornering lights installed
- ESP system installed
The G85 steering angle sensor is located in the slip ring of the steering wheel column switch.
I can provide you with the steering angle sensor G85 and necessary wiring for additional fee (EUR 60)
Also, you need the ESP disable button in the dashboard. I can provide you with the button and wiring for this too. (EUR 30)
I cannot stress out enough that you need to take good care of proper fitting. If you can't do it yourself, hire a professional.
For any questions or info, please write me a PM.
CNK
Drives: 6R
Re: Polo 6R Bosch ESP 9.0i ABS pump and control module
Post by CNK »
is it still available? :D
No some crazy polish kid bought it
CNK
Drives: 6R
Post by CNK »
Oh, what a madman, why would he need such a pump?
That's pity... but maybe you still have some other pumps in your lab? :mrgreen:
arturbo
Drives: Polo gti 6c
Post by arturbo »
Friend, could you help me make an encoding of an ESP 9.0 module on a gti 6c pole, because after a change of ECU my module appeared only in zeros, of course I would pay earlier for your help thank you
