UK-POLOS.NET - THE VW Polo Forum • numberior´s 2011 Polo 6R GTI DSG
Page 1 of 6
Posted: Fri Oct 06, 2017 8:45 am
by numberior
Hi everyone,
I open a new topic here to seek advice for mods.
The Polo is a fun car to drive and I derive satisfaction when I add new features by myself.
My stock equipment:
-Halogen headlamp
-cruise control
Mods thus far:
-tilting side mirror for parking by external module control
-folding mirrors by external module control
-LED tail lamp
-double-U projector headlamps with LED bulbs
-Boost gauge plug and play
-i-shift by EclipTech
-BMC OTA intake filter
-full exhaust system with APR stage 1 plus tuning
-in-badge RVC
-aftermarket radio built for Polo 6R
-Bilstein B12
I bought the Polo used. It seems ex-owner had someone done CH/LH mod using some external electronics.
The rotary light switch seems not stock and connects to a China made module. The other end of the module then connects to the stock connector.
It's not working anyway and they're a few wires hanging from the module disconnected.
I will be replacing the rotary switch with one that does not have fog lamp function, as I will be removing them.
Stock connector for rotary light switch:
Monday,02,October,2017,10:58:44:27502
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116   License Plate: 2OCT2017
Mileage: 99610km-61894mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBY312116   Mileage: 99610km-61894miles
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAVE)       Labels:. 03C-907-309-V1.clb
   Part No SW: 03C 906 027 AR    HW: 03C 906 027 AR
   Component: 1.4l R4 TSI   H15 9971
   Revision: L2H15---    Serial number: 00000000000000
   Coding: 00250012002400000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
   ROD: EV_ECM14TSI01103C906027AR.rod
   VCID: 71E99E02A0C274CE75-8024
Readiness: 1110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 050 K    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2669
   Revision: 00043014    Serial number: CU501309027085
   Coding: 0000020
   Shop #: WSC 00046 000 00000
   VCID: 31695E02AB4234CE35-5106
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 230248E3416E02B4C42612E382D740811700
   Shop #: WSC 00788 648 00255
   VCID: 071DD0DAB2465A7ECB-8052
   Part No SW: 6R0 907 044 E    HW: 6R0 907 044 E
   Component: Climatronic   H09 0609
   Revision: V0000000
   VCID: 35616A129C2A18EE69-8060
   Part No SW: 6R0 937 087 H    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0230
   Revision: BF046001    Serial number: 0394 106112048
   Coding: 3CB02BBF08A10000083808403C290CD020C041CF60060000200000000000
   VCID: 428B01CEDDE4BF56DC-8016
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  007 1611
   Serial number: KU0KU024031100012688
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  007 1611
   Serial number: KU0KU016031100015781
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 591 A    HW: 7P0 959 591
   Component: J245 PS72.015  H05 0006
   Serial number:     WOO1165901/
   Coding: 081001
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0050759
   Coding: 830000
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Serial number: KU0KU011041100017315
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Serial number: KU0KU011041100013053
   Coding: 08BC32
   Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
   Component: VW10Airbag01E H09 0020
   Revision: --------    Serial number: 003GZ000HCNK
   Coding: 003145
   VCID: 4C972FF6E7A0792626-8018
   Serial number: 3575HRB40550HJHG9ON%
   Serial number: 3585HRB40590HJHG919A
   Serial number: 3515RRB405B0I4AG6OGL
   Serial number: 3525RRB404R0H4DUHPLR
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 870     HW: 6R0 920 870
   Component: KOMBI         H21 0320
   Coding: 140A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   VCID: 72EB910EA5C44FD68C-8026
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 002300
   VCID: 70EF9B06A3C87DC67A-8024
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 130
                    Mileage: 98655 km
                    Time Indication: 0
                    Date: 2012.02.11
                    Time: 12:43:42
   Component: IMMO          H21 0320
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADB896E8D14871634-803E
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F6D587AEA76223E23-807A
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:08)--------------------------
Right now, I'm retrofitting xenon headlamps, and for the first time I'm doing it the OEM way, which is totally necessary to not affect others.
I have purchased from Kufatec:
1) xenon adaptors: https://www.kufatec.de/shop/en/volkswag ... vw-polo-6r
2) Autoleveling kit: https://www.kufatec.de/shop/en/volkswag ... vw-polo-6r
I have purchased separately the following:
3) Xenon headlamps with cornering lamps
4) BCM Max p/n:7E0937090B
5) Ballasts for xenon headlamps
I have already received the Kufentec merchandise and have started installing the xenon adaptor kit.
BCM Max has not arrived yet.
I've read Ciclos's and iichel's posts before embarking on this project. therefore the BCM Max....
Kufatec sells the BCM Max but does not support installation instructions and harness, understandably due to the many combinations of stock equipment in Polos.
Hope to receive help here in order to reap the benefits the BCM Max has to offer.
Cheers!
Re: numberior´s 2011 Polo 6R GTI DSG
Posted: Sat Oct 07, 2017 6:04 am
by ciclo
viewtopic.php?f=56&t=58703&start=3675#p525354
To adapt the BCM Max you must follow this installation guide.
viewtopic.php?f=56&t=69826#p520951
Yes, there is some difference in the wires reaching the Light switch/Dimmer connectors.
- Blue / Gray = Yellow / Gray (T17 connector, and T6 connector)
- You must also remove/isolate the T17/6 original wire.
As for the Chinese automatic lights kit.
It is the old kit, in the new one the black box is smaller and it does not have the red wire (this red wire in old Kit is for the CH/LH functions - when connected to the blinker wire -).
If it does not work, remove it.
For auto lights it is best with original parts. (RLS, LSW AUTO, etc.)
Posted: Mon Oct 09, 2017 12:32 pm
by numberior
Thanks Ciclo for your reply.
I have yet to get to BCM Max, as it's not yet arrived.
The Kufatec retrofit cables for xenon headlights and AFS leveling kit are installed in place.
I did a quick test yesterday with VCDS settings as per Kufatec's instructions.
I did all the VCDS config except for the one with byte 18, for fear of irreversible damage.
There was no light at all, no DRL, xenon lamp not lighting.
Please note I did the test with xenon lamps and the cornering H7, and without signal bulb, as they have not yet arrived.
Below code was autoscan with halogen headlamps installed. I will find time to autoscan with the xenon headlamps again.
Monday,09,October,2017,00:58:35:27502
www.Ross-Tech.com
VIN: WVWZZZ6RZBY312116   License Plate: AFTER ALWR SETTING LESS BYTE18
Mileage: 99980km-62124mi   Repair Order:
Scan: 01 02 03 04 08 09 15 17 19 25 44 55 56
VIN: WVWZZZ6RZBY312116   Mileage: 99980km-62124miles
55-Headlight Range -- Status: Malfunction 1010
Readiness: 0000 0101
   Coding: 0000020
   VCID: 31695E02AB4234CE35-5122
   Revision: --------
   Revision: V0000000
1 Fault Found:
00457 - Control Module for Network (J519)
            013 - Check DTC Memory - Intermittent
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 214
                    Mileage: 99987 km
                    Time Indication: 0
                    Date: 2012.03.01
                    Time: 11:37:34
   Coding: 3CB02BBF08A10000083808F13C290CD0FFC041CF60051041200000000000
   Coding: 18BC30
   Coding: 08BC30
   Coding: 081001
   Coding: 830000
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003145
   Coding: 140A00
   Coding: 002300
3 Faults Found:
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 99987 km
                    Time Indication: 0
                    Date: 2012.03.01
                    Time: 11:57:56
01771 - Control Module for Headlight Range (J431)
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 214
                    Mileage: 99962 km
                    Time Indication: 0
                    Date: 2012.03.01
                    Time: 06:49:05
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 173
                    Mileage: 99962 km
                    Time Indication: 0
                    Date: 2012.03.01
                    Time: 06:49:09
   Serial number:
   Coding: 11230
   Shop #: WSC 31414
   Revision: --------    Serial number: --------------
   Coding: 0110000001000000
   VCID: 77FDA01ACEA62AFEBB-8022
7 Faults Found:
5275220 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Fault Status: 00000001
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 174
                    Mileage: 99987 km
                    Date: 2017.10.09
                    Time: 12:51:38
5276949 - Positioning Motor for Headlight Range Left
          C1085 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 174
                    Mileage: 99987 km
                    Date: 2017.10.09
                    Time: 12:39:49
5277205 - Positioning Motor for Headlight Range Right
          C1086 15 [137] - Open or Short to Plus
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 174
                    Mileage: 99987 km
                    Date: 2017.10.09
                    Time: 12:36:36
12583424 - Databus
          U1201 00 [008] - No Communications
                    Fault Priority: 6
                    Fault Frequency: 114
                    Reset counter: 214
                    Mileage: 99987 km
                    Date: 2017.10.09
                    Time: 12:34:27
13705472 - Databus
          U1121 00 [008] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 214
                    Mileage: 99987 km
                    Date: 2017.10.09
                    Time: 12:34:22
13705474 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 214
                    Mileage: 99987 km
                    Date: 2017.10.09
                    Time: 12:34:23
13705475 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 214
                    Mileage: 99987 km
                    Date: 2017.10.09
                    Time: 12:34:23
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:16)--------------------------
I expect to at least have the low beams working. Could it be due to byte 18 not yet set properly?
How does the xenon low beams get turned on?
My car does not have the auto light on function by the way.
TIA!
Posted: Mon Oct 09, 2017 8:53 pm
by ciclo
Address 55: Xenon Range (J431)
Coding: 0114000001000000
After entering this coding you must make the basic setting.
For all other issues nothing makes sense until you adapt the wiring for the BCM Max, and install and code such BCM. It is the first step of all.
Do not worry, everything has solution. :wink:
Have you already made your adaptation wiring for BCM Max?
Posted: Tue Oct 10, 2017 4:27 am
by numberior
Hi Ciclo,
My bad. I just realise Kufatec's adaptation requires BCM Max. Pins connected to xenon lamps A2 and B2 are not even present on BCM High.
Same goes for A63, B68, A62, A5 and B3.
I should be receiving BCM Max this week.
I have a question regarding Kufatec's xenon retrofit kit though. I traced it to see the eventual routing the retrofit kit wiring brings about.
And I got this:
*Removed sketch due to incorrect interpretation.
From my understanding of the Polo 6R xenon headlamp(left) diagram, T14a/6 should be connected to T73a/2.
But Kufatec adaptor routes T73a/2 to T14a/5 and T14a/7(ground in xenon headlamp) instead, which seems incorrect?
I have not made the BCM Max cables but I will do it when I find the time.
I'd like to get xenon lamps to work first, with high beam and DRL working properly.
Are the BCM Max cables necessary for xenon headlamps adaptation?
Posted: Tue Oct 10, 2017 9:32 am
by ciclo
I hope you understand what I'm going to say.
1- please delete the sketch you've done (it hurts the view), I very much doubt that those are the instructions you received from kufatec.
2- transform 'your cables' into my installation guide (WL1, WL2, WL3). The fuses have to be pre-BCM, etc...
3- from what we have said before, what is the first step of all?
Without a correct installation a correct coding does not work, if the correct coding does not work the lights/leds of your bixenon headlights will not work.
Again, what is the first step of all? :lol:
Answer yourself to your question.
numberior wrote: Tue Oct 10, 2017 4:27 am Are the BCM Max cables necessary for xenon headlamps adaptation?
Other info:
:arrow: T10-T14
:arrow: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Posted: Tue Oct 10, 2017 9:54 am
by iichel
There are too many mistakes in the sketch to be of an use. i.e.:
- T14/5 and T14/7 says 31. Terminal 31 = GND. It's always indicated with a brown wire at VW.
- With the BCM max adaptation from ciclo, the J331 disappears. Forever.
Posted: Tue Oct 10, 2017 1:03 pm
by numberior
Hi Ciclo,
Ok, for now I will focus on making the BCM Max wirings.
Your pics are all clear.
I see that Kufatec retrofit kit has got WL2 covered, with slight differences:
1. Kufatec did not specify which fuse with permanent positive to tap. At the time of
installation, I used SB44 instead of SB59.
2. Also, instead of using electrical bridge and tapping SB39, Kufatec's instruction
was to isolate(cut) J331 pin8, then T73/A2 and B2 connects to grey/violet wiring
towards headlamps.
Now, I'm still left with the task of making WL1 and WL3.
For WL3, can you check if the end-to-end connections are correct as underlined?
I have now only the large and medium sized terminals in T73.
What's the part number for
WL1:
1.The small female BCM terminals for pins 54 and 57?
2.Thickness of twisted pair?
3.Female terminals for T32 at instrument cluster?
WL3:
1. T17 terminals
2 T6 terminals
Thanks Ciclo and iichel for your patience and help!
Posted: Tue Oct 10, 2017 8:22 pm
by ciclo
numberior wrote: Tue Oct 10, 2017 1:03 pm I see that Kufatec retrofit kit has got WL2 covered, with slight differences:
I would like to point out that it was you who have made a comparison of wiring (kufatec VS ciclo), I have always tried to avoid making comparisons in this regard (as you can see in my previous post).
The differences are gigantic. I would never follow kufatec instructions to adapt a BCM Max. NEVER. There are very powerful reasons for this.
numberior wrote: Tue Oct 10, 2017 1:03 pm 1. Kufatec did not specify which fuse with permanent positive to tap. At the time of
Well, now we have four different scenarios here to supply power (+30) to the BCM for several lights of your 6R. Pins T73a/63 and T73b/68.
1- OEM-way (factory): with two fuses prior to BCM power, one for each headlamp and other lights.
2- ciclo-way: same as OEM-way.
3- numberior-way: with a fuse for both headlights and other lights that depend on both pins.
4- kufatec-way: without fuse, direct feed.
Imagine what happens if there is a voltage peak (many reasons for this with bad electrical installations or external conditions) when you drive at 100 km/h at night.
Why do you think there is a dual system for the headlights and are combinated the High Beam from one headlight with the Low Beam from the other one in the same fuse and BCM connector on some car models like my 6R? Two fuses and connectors for both combinations.
It is for your security, in case one of the two fuses is melted you can still have some light... and avoid a difficult situation. I do not even want to imagine what would happen if the BCM is damaged by lack of fuses ...
numberior wrote: Tue Oct 10, 2017 1:03 pm 2. Also, instead of using electrical bridge and tapping SB39, Kufatec's instruction
towards headlamps.
... and all the controls and diagnostics that the BCM does in each headlight individually would have no use with this way of connecting the supply to the headlights from the BCM ...
I do not comment more on this because I do not want to extend this issue, I think it is quite clear what I mean ...
Posted: Tue Oct 10, 2017 8:35 pm
by ciclo
numberior wrote: Tue Oct 10, 2017 1:03 pm For WL3, can you check if the end-to-end connections are correct as underlined? It's correct.
WL1:
1.The small female BCM terminals for pins 54 and 57? MQS
2.Thickness of twisted pair? 0.5mm2
3.Female terminals for T32 at instrument cluster? MQS
WL3:
1. T17 terminals JPT
2 T6 terminals JPT
https://www.a4-freunde.com/showwiki.php ... uebersicht
Posted: Wed Oct 11, 2017 1:12 pm
by numberior
Hi Ciclo,
I'm making the comparison because I had already installed the Kufatec wiring before my first post here.
Not that I'm doubting your method.
Thanks for your explanation. Now there is compelling reason for me to correct the wiring.
I truly appreciate your help you extend to us here in the forum :)
Posted: Wed Oct 11, 2017 5:43 pm
by ciclo
I'm sure you will do it properly. :wink:
Posted: Thu Oct 12, 2017 6:02 am
by numberior
Hi Ciclo,
I'm trying to correct the Kufatec wiring now. Can you help me with WL2?
What's the end-to-end connections for each wire like?
Posted: Thu Oct 12, 2017 8:35 pm
by ciclo
viewtopic.php?p=525645#p525578 Image... :lol:
https://drive.google.com/file/d/0B2nv91 ... RvU2c/view
Enlarge the image and follow the red and green arrows.
Start where it says 39b, 59b.
Posted: Fri Oct 13, 2017 12:59 am
by numberior
Thank you Ciclo;)
