Does anyone know which fuse it is for the interior lights on the polo 6r? I think I've blown it changing a bulb earlyer and now non of my inside lights work and I can hear a clicking coming from the fuse box.. however vw decided it would be fun not to supply a fuse diagram. Cheers in advance!!
Sent from my XT1572 using Tapatalk
Fuse box
Re: Fuse box
SB21
10Amp
Small fuse
10Amp
Small fuse
Re: Fuse box
Without knowing that this is fact, I'm sure that I've read either on this forum or the early 6J Ibiza forum or the MK2 Fabia forum that when changing interior bulbs and then having no lights, if you find a fuse blown and replace it, you then need to scan the car to clear stored faults before the lights work again - just seeing this thread triggered that thought, as I say some or all of it might be true - though some or all of it might not be!
Re: Fuse box
Yes, it is true, it is necessary to clear the fault with a diagnostic tool.
Re: Fuse box
So a simple thing like changing a globe and blowing a fuse ends up with you having to scan and clear the car for faults,seriously now?What next?
Re: Fuse box
I thought it was only in South Africa that VW came with no diagram for the fuse layout.
joe6
Re: Fuse box
No fuse layout, no bulb info, no oil capacity info. tyre pressure info only on the fuel flap. but it does tell you what each pedal does and how to change gear so I suppose useful for aliens!!mellos wrote: Wed Oct 25, 2017 7:33 pm I thought it was only in South Africa that VW came with no diagram for the fuse layout.
