Polo 6c MPI Bordcomputer
I've got Polo 6c MPI 2014. In my instrument cluster there is no mfa ,there's only outside temperature.
I've bought new shifters with the trip button and install them to my car but the button is no working and there is still no bordcomputer.
Maybe there is no wiring to the bord computer?
Has anyone have got any schema to polo 6c which i can use to make some wiring?
Re: Polo 6c MPI Bordcomputer
Thank you
T10 is the switchers right?
And t73 is ?
And t73 is ?
benzinkopf
- Drives: 1.2TSI 105HP DSG7
in addition to the wiring, you need to enable MFA/MFD with VCDS.
T73a is one of BCM connector under the driver footwell
t73a is one of the bcm plugs, on drivers left
And one last question?
Do you know what is oem connection numbers to BCM and to shifters
benzinkopf
here you go.iichel wrote:
pin as per T73a above. 15, 16, 17
i mean what pin/connector shall I use to connect the wires to BCM and shifters
https://www.drive2.com/l/6920518/
like on this website
stalks: MCP 1.5
BCM: micro quadlock system
Hi again
Where to enable boardcomputer in vcds?
Anyone??
I'm sorry but I don't know. Did you check VCDS yourself for any labels?
