UK-POLOS.NET - THE VW Polo Forum • Polo 6R with 7E0 BCM - problem with gateway installation list
Posted: Mon Nov 13, 2017 10:02 am
by diskoboy
Below is a complete scan from my car this weekend.
I've retrofitted the 7E0 937 090 BCM, but my problem is the 04, 37 and 77 module.
They are not in the car and in the gateway installation list they are NOT checked. Why does they show up?
Saturday,11,November,2017,15:31:26:21096
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZBY11xxxx   License Plate: POLO
Mileage: 125730km-78125mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 44 55 5F 77 0B
VIN: WVWZZZ6RZBY118804   Mileage: 125730km-78125miles
04-Steering Angle -- Status: Not registered 0001
37-Navigation -- Status: Not registered 0001
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 EP    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 6006
   Revision: --------    Serial number:
   Coding: 00114016002401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM16TDI02103L906023EP 001003
   ROD: EV_ECM16TDI02103L906023EP_001.rod
   VCID: 78F45C69C3812386B2-802C
Readiness: 1010 0000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416E00BA842D14E282D500521300
   VCID: 06082291B5754576B0-8052
Address 08: Auto HVAC        Labels: 6R0-907-044.clb
   Part No SW: 6R0 907 044 B    HW: 6R0 907 044 B
   Component: Climatronic   H08 Climatronic   H08 03050305
   VCID: 3260AE416D7D09D64C-FFFE
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 316153256
   Coding: 3CB02FBF68EB2400B3380FD17CEB9FD8DAC067AF608D70D0200000030800
   Shop #: WSC 12345 123 12345
   VCID: 68D40C299B21B30622-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 150415 03  37  0059
   Coding: 028877
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU027.09.1014111
   Coding: 58BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU023.09.1012131
   Coding: 48BC30
   Subsystem 4 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 29150000228280105063
   Coding: A4FFFF
   Subsystem 5 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Serial number: KU0-KU021.09.1015081
   Coding: 48BC32
   Subsystem 6 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Serial number: KU0-KU020.09.1011045
   Coding: 48BC32
3 Faults Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 76
                    Mileage: 125739 km
                    Time Indication: 0
                    Date: 2012.04.03
                    Time: 15:15:49
03156 - Sensor for Anti-Theft System (G578)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 76
                    Mileage: 125739 km
                    Time Indication: 0
                    Date: 2012.04.03
                    Time: 15:15:50
01229 - A/C Humidity Sensor (G260)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 76
                    Mileage: 125739 km
                    Time Indication: 0
                    Date: 2012.04.03
                    Time: 15:15:50
   Part No SW: 7E0 919 475 E    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H11 0013
   Revision: --------    Serial number: 47401112400302
   Coding: 308001
   Shop #: WSC 01723 013 01313
   ASAM Dataset: EV_VW75XParkAssis8K A01005
   ROD: EV_VW75XParkAssis8K_A01.rod
   VCID: 346CA8599F6907E65E-8060
   Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Component: VW10Airbag00G H09 0020
   Revision: --------    Serial number: 003GY001782S
   Coding: 003047
   VCID: 4B9ED3A5E297781E2F-801E
   Serial number: 3572SRB40000CA24E279
   Serial number: 3582SRB40000CA24A8CH
   Serial number: 3515RRB406301NFS7HHS
   Serial number: 3525RRB405L010DAB8D.
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 861 F    HW: 6R0 920 861 F
   Component: KOMBI         H04 0304
   Coding: 140E00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   VCID: 38749C698301E38672-806C
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 002200
1 Fault Found:
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 125739 km
                    Time Indication: 0
                    Date: 2012.04.03
                    Time: 15:26:03
Address 20: High Beam Assist. (J844)       Labels:. 8S0-857-511.clb
   Part No SW: 7E0 857 511 E    HW: 7E0 857 511 E
   Component: FLA           H09 0002
   Revision: AA001001
   Coding: 040400E200000000000000
   Shop #: WSC 02739 790 50316
   ROD: N/A
   VCID: 2C5CB03947595F2606-8078
No ASAM data for: "EV_HighBeamAssisAU316" (VW25)
   Component: IMMO          H04 0304
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6AD076218D2D811634-803E
Address 37: Navigation
Cannot be reached
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F66A735EA4F243E23-807A
   Revision: --------    Serial number: --------------
   Coding: 0392000001000000
   Shop #: WSC 00066 123 12345
   VCID: 77F65F55CE9F2CFEBB-8022
Address 5F: Information Electr. (J794)       Labels:. 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Component: MU-S-N-ER     H20 0241
   Serial number: VWZAZ2R8812891
   Coding: 026200013C0000001111000100080A031F0106D400200100CF
   Shop #: WSC 35110 790 50316
   ROD: N/A
   VCID: 204454093B918B46AA-8074
   Subsystem 1 - Part No SW: 3G0 919 866 H    HW: -----------
   Component: ECE 2015/16  --- 0430
No ASAM data for: "EV_MUStd4CTSAT" (VW25)
2 Faults Found:
3077 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 76
                    Mileage: 125739 km
                    Date: 2017.11.11
                    Time: 15:15:44
0003 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 76
                    Mileage: 125739 km
                    Date: 2017.11.11
                    Time: 15:15:44
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:21)--------------------------
Re: Polo 6R with 7E0 BCM - problem with gateway installation list
Posted: Mon Nov 13, 2017 2:30 pm
by iichel
maybe it's standard in VCDS to scan hem? you can customize it.
Posted: Mon Nov 13, 2017 2:40 pm
by diskoboy
You've got a point... However then I'll just wonder what's wrong with the coding in the gateway...
A 2nd question: Anyone knows how to turn on the rear lights during daytime?
Posted: Mon Nov 13, 2017 3:03 pm
by iichel
you can have byte 12 bit 0 but it will turn on front parking lights as well. in your case the LEDs will probably stay bright because of 7E0 bcm
Posted: Fri Nov 17, 2017 7:55 pm
by ciclo
diskoboy,
04 must be registered in the Gateway Installation List.
Some small coding corrections
BCM
(humidity sensor not installed)
3CB02FBF68EB240093380FD17CEB9FD8DA8067AF608D30D0200000030800
RLS
0728DD
You should have installed this :arrow: RLHS in your 6R Bluemotion. ...with HBA.
Check the LIN (T73b/24) for the (G578) alarm sensors and A/C Humidity Sensor (G260). (same LIN as RLS LIN)
Check the LIN (T73b/36) for the H12 alarm horn.
On the other hand, it seems that the patch that has been used for your :arrow: 5F unit is not good enough, something weird here.
Have you checked that the coding is correct?
From T6 with 5F there are many autoscan in several forums. Also here.
Where is your 61 address? :lol:
