Bixenon headlights with AFS For polo gt Tsi 2015
hmthakur
- Drives: Polo gt tsi 1.2 dsg
hi,
I am going to fit valeo bixenon headlights with cornering ability and afs to my polo gt tsi
hmthakur
Re: Bixenon headlights with AFS For polo gt Tsi 2015
FUSE BOX
hmthakur
Switch back side
All good. Best of luck
Hi hmthakur
(in response to your email)
Why did not you open a topic like this as was required at that time
(August 16, 2017)?
Now it is impossible for me to make your harnesses. I would like to make them, but it is not possible due to lack of time.
However, for BCM adaptation this is what you have to do:
https://drive.google.com/file/d/0B2nv91 ... V5a1k/view
Maybe these links are useful for you:
viewtopic.php?f=56&t=70289&start=60#p524669
viewtopic.php?f=56&t=70289&start=60#p524704
viewtopic.php?f=56&t=70289&start=75#p524786
The requested information was:
Pictures from,
Relay carrier
Light Switch connector (original)
Dimmer connector
Fuse box
New BCM.
VCDS Autoscan. Recent.
I insist, I regret not being able to manufacture your harnesses. I will help you here, in your topic.
You must provide all the possible information that is related to your new project so that we are able to help you.
Pictures from,
Relay carrier
Dimmer connector
Fuse box
New BCM.
Hi hmthakur
(in response to your private message)
Because you requested the manufacture of the harnesses before the stipulated date I will manufacture your wiring.
You have to provide the requested information here in your topic. I think I've asked you for this information on countless occasions. Maybe I live on a different planet, but I wonder if it is so difficult to understand that without this specific information from your 6R I can not manufacture your wiring.
You need several harnesses for your new project: (priority and mandatory for your project)
1- BCM adaptation wiring + wiring for automatic lights. (B in the sale, same conditions)
2- RLS wiring + Dimiming mirror wiring (20€). You have to tell me the reference number of the interior mirror that you are going to install.
A part of the BCM adaptation wiring that I make is the Dimmer for interior lights, you have to buy this model: 6Q0941334 (it's used with bixenon headlights), explained in the installation guide.
3- T10 - T14 adaptation wiring for Bixenon headlights.
4- AFS wiring.
I do not manufacture harnesses 3 and 4 (I never did), but they are for sale on several websites.
All communication for technical support will be through this topic. Not by emails, or private messages.
All communication for Shipping, Payment, etc... will be by email. Not by private messages.
4- AFS wiring.
hmthakur
Thanks buddyciclo wrote:Hi hmthakur
4- AFS wiring.
I will post all the photographs tomorrow
Ok. Do you have the BCM Max 7E0? In case you do not have it, get in touch with firegrafik, maybe he can help you in this regard.
Tomorrow?hmthakur wrote: Thu Dec 21, 2017 8:55 am Thanks buddy
How long is a day on your planet? from Dec 21 up today.
From now you have 72 hours to post the pics, otherwise I will not make your wiring, you can be sure.
(without the pics I can not manufacture your wiring, for the umpteenth time)
A big hug... buddy.
hmthakur
Sorry buddy down with severe flu
ok... take care.
I hope you are recovering from the flu.
FYI
1- BCM adaptation wiring + wiring for automatic lights. It's already manufactured.
2- RLS wiring + Dimming mirror wiring (20€). You have to tell me the reference number of the interior mirror that you are going to install.
viewtopic.php?f=56&t=70698&p=528200#p528005
FYI
hmthakur
I want wiring loom number 2 for rls + dimming mirror
Parts acquired by me till now
BCM 70
Auto dimming mirror
RLS
Auto switch already purchased and installed
Searching for bixenon headlights
BCM 70
Auto dimming mirror
RLS
hmthakur
attaching latest vcds scan report
Monday,01,January,2018,19:19:45:19846
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: MEXC15608FT079060 License Plate: 01-01-18-2
Mileage: 9220km-5729mi Repair Order:
Chassis Type: 60 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44
VIN: MEXC15608FT079060 Mileage: 9220km-5729miles
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056232400080000
Shop #: WSC 00793 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6D84C00F1D15260FF6F-8038
Readiness: 0110 0101
Part No SW: 0AM 300 062 R HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6201
Revision: 00043014 Serial number: CU501412085377
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 3B203E571F6178BF38B-806E
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 BH HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422A03C94614246F4251C0800904
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 055498AF25A5FE4F1EF-8050
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Serial number: 11121404651355
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA6F7434073AD975F5-802A
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40DA49BB7A871B676D9-8014
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 R HW: 6R0 937 087
Component: BCM PQ25 H+4 H34 0424
Revision: BF034001 Serial number: 0681 336140556
Coding: 3AB02BBF08A30000003800007C2B9C9000C0414F608C0000200000000000
Shop #: WSC 124697 483 00190
VCID: 4CC26D8B46CFCF07811-8018
Subsystem 1 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Serial number: 13202576141210080401
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Serial number: 13202579141210182244
Coding: 010000
Subsystem 3 - Part No SW: 13 202 579 14 HW: 132 025 791 41
2101
Serial number: ÿ132025791412101822
Coding: 323234
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Serial number: 13202580141106012556
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581141125202458
Coding: 020000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00XAULG
Coding: 003036
VCID: 49CC549F493DDA2FBA7-801C
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140800
Shop #: WSC 13202 938 00000
VCID: 47C852A75F292C5FAC3-8012
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0424
Revision: BF034001
Coding: 002300
VCID: 70BAD97B0AA7CBE7DD9-8024
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H05 0805
VCID: 6A8ECB132CFB313793D-803E
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014_VW12.rod
VCID: 41DC4CBF710D126F627-8014
End----------(Elapsed Time: 00:55, VBatt start/end: 13.9V/14.0V)-----------
www.Ross-Tech.com
Coding: 0000020
Coding: 01
Revision: V0000000
Coding: 010000
Coding: 010000
2101
Coding: 323234
Coding: 020000
Coding: 020000
Coding: 003036
Coding: 140800
Revision: BF034001
Coding: 002300
