UK-POLOS.NET - THE VW Polo Forum • Low mileage Polo - can I use an AGM battery?
Posted: Mon Jan 01, 2018 4:47 pm
by goldnet
Hi
My 4 year old battery needs replacing. My lovely 96 Polo is rarely used and, of course, requires regular charging to keep enough charge to start it!
I read AGM batteries hold their charge longer and are not so damaged by charging/depletion and, as well as stop/start vehicles, are also suitable for low mileage use.
Can I simply fit one to my Polo? Anyone have any recommendations?
Re: Low mileage Polo - can I use an AGM battery?
Posted: Tue Jan 02, 2018 10:46 am
by alexperkins
AGM charging is completely different to lead acid charging. The battery needs digital management which the 6N does not have
If you dont drive it regularly, get a normal lead acid battery, and stick the car on a trickle charger
