I think my actuator has failed/failing. The car keeps going into limp mode with fault code P0344-B00 (I think, I've lost the damn receipt !!), but it indicated a turbo/actuator problem. Which the car has had in the past.
The car is a 1.2TSI 105 SEL. 2010 plate.
How difficult a job is it to change the turbo actuator ? Or can it be repaired/lubricated or anything ?
Can it be done with normal hand tools ? Does it need any software type setup/calibration ? Or is it a straight bolt on swap over jobbie ?
Cheers.
Turbo actuator
Re: Turbo actuator
P0344 is camshaft position sensor - nothing to do with the turbo actuator
http://wiki.ross-tech.com/wiki/index.php/16728/P0344
