Idle revs question
whitty_77
Drives: Polo 17
Idle revs question
Post by whitty_77 »
1.2 TSI 2017
If I have heater set to 0 the revs are around600
If I have heater set to 1 the revs are around 900
Is this normal?
When they are 600rpm and I lift clutch the rpm does raise by itself.
Re: Idle revs question
sound like pretty normal behaviour to me.
Higher the load on the engine, the higher the idle revs as it compensates for increased load.
AndreiAdonis-Ganea
Drives: Polo 6R 1.6 TDI Blue Motion 90 HP
Post by AndreiAdonis-Ganea »
Tried today on my 1.6 TDI - revs stay the same. No change at all.
Maybe TDIs work differently than TSI.
Sent from my SM-G925F using Tapatalk
Does also depend how warm the engine is
Have you tried it when it’s at full temp?
Ricmondo
Drives: Polo Blue GT
Post by Ricmondo »
The basic architecture of the compression ignition engine makes it reluctant to increase or decrease its revolution speed so you would be far less likely to notice any fluctuation.
Interestingly if you have ultra sensitive instrumentation connected to your Diesel engine you would be able to detect a measurable increase in fuel consumption when an additional load, even a very small one is applied, you would also notice that the state of battery charge has an effect. We are talking about very small measurements but they nicely demonstrate the practical application of Newton’s Laws.
whitty_77
Drives: Polo 17
Post by whitty_77 »
It does it all the time on my Tsi
soon as I put heater on 1 the revs always settle at around 900. set to 0 and the revs settle at 600
so we saying this is normal behaviour of a tsi
Thanks all
600 is quite a low idle. If it’s under warranty I’d take it in to get it checked over
whitty_77
Drives: Polo 17
Post by whitty_77 »
Is it not part of the bluemotion technology?
it doesn't struggle, just odd that it differs so much,
Ive seen cars when you put air con on and the revs raise a bit but this is just the normal heater.
can anyone else with a 1.2 TSI 6c confirm if its normal?
whitty_77
Drives: Polo 17
Post by whitty_77 »
Just did a quick serve for revs on 1.2 tsi and found this
https://www.youtube.com/watch?v=yTk23MYy748
the starting revs are about the same 600-650
Oh yes, of course it has BMT.
Maybe someone else with a 1.2 TSI can confirm the rev behaviour
