How take the 12v signal [Polo 6r]
Posted: Fri Feb 23, 2018 11:14 am
by firebulletz
Hello to all,
I should make some changes to my polo but I would need to know where I can take the 12v at some points.
I should mount:
- footwell lights (front and rear)
- goalkeeper lights (4 doors)
- neon strips on the door panels
For the first and second I have no idea if I can connect directly to the fuse, and I do not know if connecting them I should do some additional wiring up to the bcm (I prefer not)
For the neon signs instead I would like to be able to adjust them with the brightness regulator of the internal leds of the machine, perhaps taking the signal from the window switch of each door. I've already tried but without success, the tester gave me a signal of 1 volt and 0.4 amps, but I need the 12v (but 5 would be fine).
On photo you can see the neon strip (it was connect to usb only for test)
Inviato dal mio SM-G935F utilizzando Tapatalk
Re: How take the 12v signal [Polo 6r]
Posted: Mon Feb 26, 2018 5:17 pm
by Roh4nms
I’m looking to do the same! Could you post the links to the website you’ve got your ambient lighting kits from.
Posted: Mon Feb 26, 2018 5:32 pm
by firebulletz
Roh4nms wrote:I’m looking to do the same! Could you post the links to the website you’ve got your ambient lighting kits from.
This is the link:
http://s.aliexpress.com/ABJje6J3?fromSns=Copy to Clipboard
[emoji16][emoji16]
Posted: Wed Feb 28, 2018 10:18 pm
by Roh4nms
firebulletz wrote:Roh4nms wrote:I’m looking to do the same! Could you post the links to the website you’ve got your ambient lighting kits from.
This is the link:
[emoji16][emoji16]
Cheers appreciate it
Posted: Thu Mar 01, 2018 11:20 am
by Roh4nms
So how do you intend to conceal the large connection adapter they come with?
Also have you found where to splice off for the door rests lights (and footwell) because I too thought it would work off the electric window switch but you say that doesn’t work.
Let me know how yours goes and I will be following suit if it turns out to be a simple task.
Posted: Fri Mar 23, 2018 12:24 pm
by firebulletz
Roh4nms wrote:So how do you intend to conceal the large connection adapter they come with?
I do not have the footwell lights. I would like the light to remain on when the lights are on, not just when the doors are opened. I saw that on golf 6 it is possible to take the signal from the window winder connector or from the door connector, but I do not think they are the same
Posted: Fri Mar 23, 2018 12:25 pm
by firebulletz
Posted: Sat Mar 24, 2018 8:39 pm
by ciclo
You need a 58 or 58d signal.
Open a personal topic in 6R section, show us your 6R and I help you with this.
Posted: Tue Mar 27, 2018 3:19 pm
by firebulletz
ciclo wrote:You need a 58 or 58d signal.
Open a personal topic in 6R section, show us your 6R and I help you with this. [emoji38]
I opened it
