Wiring lighting for boost gauge
cheba
Drives: Polo R WRC 2014
Re: Wiring lighting for boost gauge
Post by cheba » Mon Apr 16, 2018 9:59 pm
ciclo wrote:
Mon Apr 16, 2018 6:01 pm
For the red wire you can take the power from the fuse box, 12V, +15 signal. :arrow: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
You must put a mini fuse to supply power to the red wire, for example 2A (gray).
The yellow wire, for example, connected to T10/9 original wire in the red connector for automatic lights (dimmed voltage -58d-). Already protected by the BCM.
In any case you must follow the manufacturer's instructions.
Wouldn't it be possible then to use switched +12V in the lighting harness for the red wire to the gauge? I'm thinking about T4 in Auto switch connector (T1 in small black 2-pole connector). Isn't that also protected by the BCM?
The manufacturers instructions only say to connect red to any switched +12V and yellow to the dimmer switch, without a fuse on any of them... but using fuses sounds like a good idea.
Drives: Polo 6R '13 / Golf MK7.5 '19
Post by ciclo » Tue Apr 17, 2018 5:38 am
Don't touch my harness for the automatic lights, NEVER!, I'll be mad with you if you do it. :lol:
Imagine that one day you decide to remove the harness for automatic lights.
What would happen with the boost gauge? :wink:
cheba
Post by cheba » Tue Apr 17, 2018 8:08 pm
Well, what would happen is that I would notice that the boost gauge is connected to your harness, and I would just have to move the boost gauge wires to the other side of the connectors before removing your harness from the connectors :D
(Don't worry, I will leave your auto light harness untouched)
