Sub power cable through firewall
Re: Sub power cable through firewall
That’s the only photo I could find of mine. You should be able to work out where i routed it via though
TheRealRyno
Drives: Mk2 Polo F
Post by TheRealRyno »
Yeah I tried that one aswell I've just been struggling to remove the grommet. It's a lot harder than the first one. What's the best method?
Squeeze and pull though I have a feeling a pierced a hole in it and siliconed it up
TheRealRyno
Drives: Mk2 Polo F
I've removed it but the grommet looks designed to just hold one wire. So how do I protect the second wire from rubbing against the metalwork?
Post some more photos if you can
TheRealRyno
Drives: Mk2 Polo F
TheRealRyno
Drives: Mk2 Polo F
What if I was to slit it open one side and wrap it round both wires then just push it back into the hole. Would something like that work?
That’ll work. Do that 👍🏻
TheRealRyno
Drives: Mk2 Polo F
Okay I'll give it a go thanks for your help. I'll post later to let you know how it goes.
TheRealRyno
Drives: Mk2 Polo F
Took a while but I got it all sorted and wired up in the end. Cheers for your help Alex. Much appreciated.
