UK-POLOS.NET - THE VW Polo Forum • BCM max, RLS, Bixenon adaptation for my 6R Sedan
Page 1 of 4
Posted: Sun May 27, 2018 5:17 am
by sreeramkumars
Hi Ciclo and other 6R veterans,
I've a 2015 1.2TSI 105bhp 6R Polo Sedan in INdia that originally came with 087k BCM. It was recently upgraded to BCM max (7E0 937 090 C) using Nikhil's help for retrofitting cruise control and we are left with one problem that he reached out to you here.
I'm also planning to retrofit -
1. Auto RLS (on the way)
2. maxidot cluster (6R0920870; already with me)
3. OEM valeo Bixenon headlights (year end).
Could you please help in providing a wiring kit and any other required accessory (such as dimmer) that can help in adapting the new BCM max fully, as well as provisioned for my subsequent upgrades. I'm in UK next week and can receive the wiring there; but would be installing only in July due to stay in UK.
Below is my full VCDS scan
Saturday,26,May,2018,11:56:35:30570
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0
Data version: 20130910
VIN: MEXA15604FT070170   License Plate: 4433
Mileage: 21515   Repair Order: 1
Chassis Type: 60 (7E0)
Scan: 01 02 03 08 09 10 15 17 19 25 44 56
Address 01: Engine (J623-CBZB)       Labels: None
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number:
   Coding: 00250056232400080000
   Shop #: WSC 00793 648 00255
   ASAM Dataset: EV_ECM12TFS02103F 004006
   ROD: N/A
   VCID: 6DD7B9F6BCE6947640B-8038
No ASAM data for: "EV_ECM12TFS02103F" (VN75)
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-927-769.lbl
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6502
   Revision: 00043014    Serial number: CU501411275963
   Coding: 0000020
   Shop #: WSC 64455 001 1048576
   VCID: 3A7D42AA7528F3CE959-806F
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 BH    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2C63412A07C0461534708251E0800904
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   ROD: EV_Brake1ESP90iBOSCH_AU21.rod
   VCID: 850761560456CC3628B-80D0
   Part No SW: 6R0 907 044 P    HW: 6R0 907 044 P
   Component: Climatronic   H12 0614
   Revision: V0000000
   VCID: 40893042D3F4A91EDBD-8015
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 322171532
   Coding: 3A904AB808A10000003800C03C099490F0C041FF60040000200000000000
   Shop #: WSC 00788 648 00255
   VCID: 2B5377EE4A725A461EF-807E
   Subsystem 1 - Part No SW: 6R0 959 802 AL    HW: 6R0 959 802 AL  Labels: 6R0-959-802.CLB
   Component: -------------  006 5520
   Coding: 010000
   Subsystem 2 - Part No SW: 6R0 959 801 AH    HW: 6R0 959 801 AH  Labels: 6R0-959-801.CLB
   Coding: 010000
   Subsystem 3 - Part No SW: |55 205 980 1A    HW: 552 059 801 AH
   Subsystem 4 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Coding: 020000
4 Faults Found:
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 6
                    Mileage: 21269 km
                    Time Indication: 0
                    Date: 2015.03.17
                    Time: 04:14:19
03432 - Activation of Right Parking Light
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 6
                    Mileage: 21269 km
                    Time Indication: 0
                    Date: 2015.03.17
                    Time: 04:14:19
01516 - Terminal 30; Left
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 44
                    Reset counter: 19
                    Mileage: 21269 km
                    Time Indication: 0
                    Date: 2015.03.17
                    Time: 04:04:12
00927 - Terminal 30 (Right)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 44
                    Reset counter: 19
                    Mileage: 21269 km
                    Time Indication: 0
                    Date: 2015.03.17
                    Time: 04:04:12
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 K    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0106
   Revision: --------    Serial number: 35821404004439
   Coding: 300001
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K.rod
   VCID: 3A7D42AABD28F3CE959-806F
   Revision: --------    Serial number: 003GW00WKAN7
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 499F2D66E8CE68560C3-801C
   Part No SW: 6RF 920 860 Q    HW: 6RF 920 860 Q
   Component: KOMBI         H02 0152
   Coding: 140800
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04719
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 58B9F822236401DE83D-800D
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 102300
   VCID: E8D948E21B04315EB3D-80BD
   Component: IMMO          H02 0152
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EADD32EA0D08034EA59-80BF
Address 44: Steering Assist (J500)       Labels: 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_SE12.rod
   VCID: 418F3546D0FEA016D43-8014
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
   Component: MIB2-S-R-CN   025 0210
   Revision: -----001    Serial number: 03925GD0082306
   Coding: 0000040001000A
   VCID: 45872156CCD68C36E8B-8010
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 6
                    Mileage: 21271 km
                    Time Indication: 0
                    Date: 2015.03.17
                    Time: 04:45:01
End   ---------------------------------------------------------------------
Re: BCM max, RLS, Bixenon adaptation for my 6R Sedan
Posted: Mon May 28, 2018 4:17 am
by ciclo
Hi sreeramkumars, welcome :wink:
B :arrow: - Wiring for BCM Max adaptation + Automatic Lights Wiring + CH/LH (135 €)
Intallation guide
https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Requested information (ASAP... to be able to send your wiring looms to UK on time)
Pictures from; (see the installation guide for reference)
Relay carrier. :?:
Light Switch connector. (colors of wires, both sides) :?:
Dimmer connector. :?:
Fuse box. :?:
New BCM.
VCDS Autoscan. Recent. OK
What Auto dimming mirror you have planned to install? Part number? :?:
Dimmer
6Q0941334 ... NEW. OEM. From my VW dealer = 40€ --> Same as this one.
Many reasons for this price (paypal, increases in paypal rates, "etc"), I don't get anything, Oh yes, headaches due to management. :lol:
Apart from all this, if you want this wiring for Dimming mirror and RLS = 30€
+ Shipping to UK (7 to 10 days) = from 500gr to 1000gr (approx 800gr) = 16€
Full Support here, in your topic.
When you post the resquested pictures I will manufacture your wiring looms and when I finish them I will contact you by email for payment.
Easy, fast, safe ... Impossible to be clearer in front of everyone.
And everything will work like a charm in your Vento/Sedan! :)
Posted: Tue May 29, 2018 9:36 am
by sreeramkumars
Thanks Ciclo for the walm welcome and reverting back.
Below are the pictures. Hope they are clear and good enough.
1. Relay carrier.
Relay Carrier
Relay Carrier
2. Light Switch connector. (colors of wires, both sides)
Light Connector 1
Light Connector 1
Light Connector 2
Light Connector 2
Light Connector 3
Light Connector 3
3. Current headlight and dimmer switch
Light Switch
Light Switch
4. Dimmer connector.
Dimmer connector
Dimmer connector
Dimmer connector
Dimmer connector
4. Fuse box.
Fuse
Fuse
Please note I've highlighted two fuses which are actually retrofitted via fuse plug. The two green ones are for dash cam and the single red one is for existing Gentex auto dimming mirror.
5. New BCM.
BCM Max
BCM Max
In terms of new parts, below are the part numbers.
1. Auto dimming mirror - 3G0.857.511.AC 9B9
2. Rain and light sensor - 5K7.955.559.C
3. Light switch with auto mode - 3С8941431А
And yes, I'll also go for the dimmer 6Q0941334 you have suggested.
Please let me know if anything else is missing. We can take the price and payment details via PM when done with required details.
Thanks and Regards,
-Sree.
Posted: Tue May 29, 2018 8:31 pm
by ciclo
Very good pictures 8) , thank you very much!
- Dimmer ordered to my VW dealer. It will take 7 to 10 days to get from Germany to Spain.
- In the meantime I will manufacture your wiring looms and inform you of the process here.
It is not clear to me if you want the wiring for Auto dimming mirror and RLS.
:arrow: https://uk-polos.net/viewtopic.php?f=56 ... 60#p524696
Can you please explain to me why you need to use two fuses for the dash cam (43,44)?
Or is it just fuse 44?
It will be necessary to reassign the power/feed of the dash cam in another slot, we need the slot 44 for a better installation. No problem for this, I'll tell you how to do it, it's very easy.
Posted: Wed May 30, 2018 4:20 am
by sreeramkumars
Hi Ciclo,
Many thanks for reverting back.
Yes, I want the wiring for Auto dimming mirror and RLS as well.
Regarding the dashcam, the 2 fuses are slotted into 43 via a single fuse tap (done by the dash cam installer). I removed fuse tap and connected fuses directly to 43,44 for sending the picture to you. Apologies if it had caused any confusion.
Thanks and Regards,
-Sree.
Posted: Wed May 30, 2018 6:35 am
by ciclo
OK.
To prevent confusions, can you draw in the next image how the feed of the Dash Cam is connected?
Posted: Thu May 31, 2018 5:02 am
by sreeramkumars
HI Ciclo,
Attaching a couple of pictures to help understand.
1. The wire from dashcom is connected to the fuse box using this fuse tap
2. The fuse tap on the fuse box in slot 43. 44 is empty but covered by the fuse tap. I removed the fuses and connected them to the main fuse box in earlier picture. Apologies if it had caused any confusion.
Regards,
-Sree.
Posted: Thu May 31, 2018 8:38 am
by ciclo
Hi, thank you for your explanations. All is clear now.
It's a horrible way (pardon for my words :lol:) to connect Dash Cam feed in the fusebox. Hides other fuses.
I will provide you with a clearer and easier way (with an image to install it). :wink:
Your wiring looms are made 95%. Soon an image of them.
The bad news. My VW dealer told me that the Dimmer will take 10-12 days to arrive. :x :lol:
Hmm... 10-12 days from DEU to SP, + 7-10 SP to UK, is it Ok for you?
Posted: Thu May 31, 2018 9:28 am
by sreeramkumars
Thanks Ciclo.
If the kit can be delivered on or before 20th June, I'll take it in UK..Any later will have to be shipped to India. We can decide this few days later.
Thanks again for progressing on my wiring.
Regards,
-Sree.
Posted: Thu May 31, 2018 12:56 pm
by ciclo
sreeramkumars wrote: Thu May 31, 2018 9:28 am If the kit can be delivered on or before 20th June, I'll take it in UK..Any later will have to be shipped to India. We can decide this few days later.
Ok, hope we have luck. :wink:
100%
:arrow: https://i62.servimg.com/u/f62/18/94/39/39/133.jpg
Installation guide :arrow: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
:arrow: https://i62.servimg.com/u/f62/18/94/39/39/231.jpg
:wink:
https://i62.servimg.com/u/f62/18/94/39/39/811.jpg
Note: Use the SB10b slot instead of SB15b, or not. :lol: (currently occupied by Gentex Auto Dimming Mirror).
I'll send you my email by private message when I receive the Dimmer. (for payment, etc)
Posted: Thu May 31, 2018 1:19 pm
by iichel
Still wondering why need a 20A fuse for a dashcam. Does it come with an integrated heater? ;) (just kidding)
As always, big respect for your wiring skills ciclo!
Posted: Thu May 31, 2018 5:16 pm
by ciclo
iichel wrote: Thu May 31, 2018 1:19 pm Still wondering why need a 20A fuse for a dashcam. Does it come with an integrated heater? ;) (just kidding)
I wonder the same thing. However, I respect the decisions of the installer or manufacturer (I don't know what the appropriate value of the fuse will be, 3A?, 5A?,10A? Max, 5A is more than enough). In any case it will work until it burns :lol: (just kidding too).
iichel wrote: Thu May 31, 2018 1:19 pm As always, big respect for your wiring skills ciclo!
:wink:
The worst part always is taking the pictures. I hate it. :lol:
Posted: Fri Jun 01, 2018 7:09 am
by sreeramkumars
ciclo wrote: Thu May 31, 2018 12:56 pm..
100%..
Installation guide
Excellent as always. Thanks a lot Ciclo for getting everything ready.
Posted: Fri Jun 01, 2018 7:11 pm
by ciclo
I hope that the images are clear for you to be able to do the installations.
Now we must be patient and wait for the Dimmer. I'll keep you informed of any new event.
Posted: Fri Jun 08, 2018 9:39 pm
by ciclo
No news yet from my VW dealer for the Dimmer. :|
I am afraid that your wiring looms will be sent to India.
