Vcds security access code
Posted: Tue Jun 26, 2018 8:51 pm
by redpolo6r
Hello, can sameone tell me vcds security access code? I want to enable stagging on my vw polo 6r 2010 1.6TDI 66kw.
Re: Vcds security access code
Posted: Tue Jun 26, 2018 9:00 pm
by Dink
If you go to security access first then hover over the box to enter the number with your mouse it should pop up with the code you need.
Posted: Wed Jun 27, 2018 9:27 am
by peter_dk25
Dink wrote: Tue Jun 26, 2018 9:00 pm If you go to security access first then hover over the box to enter the number with your mouse it should pop up with the code you need.
Not in all locations
Posted: Wed Jun 27, 2018 2:32 pm
by redpolo6r
like peter_dk25 said. Not in my case :(
Posted: Wed Jun 27, 2018 3:00 pm
by peter_dk25
As far as I remember Staging is done in 17 Instruments, 10 Adaption. No code is needed for this in the 6R. It's called "Indicator Celebration" in the Menu. You find it near the end of the Adaptions. Search YouTube
Posted: Wed Jun 27, 2018 5:02 pm
by redpolo6r
yes i found it but i can turn it OFF/ON. I need this security access code :(
Posted: Thu Jun 28, 2018 5:33 am
by peter_dk25
Strange? I have a Blue GT 6R and it did not ask for any security code in order to activate Staging in the Adaption channel.
Posted: Thu Jun 28, 2018 7:06 am
by ciclo
maklan wrote: Wed Jun 27, 2018 5:02 pm yes i found it but i can turn it OFF/ON. I need this security access code :(
NO.
It's highly probable that due to the old software (2010) of your Instrument cluster (IC) it is not possible to activate the "indicator celebration" function through VCDS.
This has already happened to others.
In the forum there are experts who could edit the eeprom of your IC to make it possible. (search)
Posted: Thu Jun 28, 2018 6:13 pm
by redpolo6r
i think you are right because i can see Indicator_celebration but i can turn it on.
That is bad news for me :(
i really like stagging :cry:
