UK-POLOS.NET - THE VW Polo Forum • Brake clunk
Page 1 of 2
Brake clunk
Posted: Wed Jun 27, 2018 7:16 am
by Polo+Pete
Hi there, I have a 2018 Polo SE and when reversing the brakes clunk on first press. It didn’t happen on my old Polo. Does anyone know if this is normal?
Re: Brake clunk
Posted: Wed Jun 27, 2018 7:45 am
by SRGTD
It’s likely that a small movement of the brake pads in the brake calipers is the reason for the ‘clunk’ noise you’re hearing. I’ve read that it’s quite normal and shouldn’t be anything to worry about. My previous generation Polo used to do this when it was new; I’ve not noticed it doing it recently though.
If you do a quick internet search, you’ll see it’s quite common.
Re: Brake clunk
Posted: Wed Jun 27, 2018 8:03 am
by RUM4MO
That is annoying, my wife has had Polos with rear disc brakes since September 2002 and never ever have either of her cars had that issue.
Re: Brake clunk
Posted: Wed Jun 27, 2018 1:20 pm
by mike sel
Yea the SE has drum rear brakes. you have to go up to the R line or SEL to get rear Disks that's is for the 115hp engine which is not available on the SE and below.
I have only done 450 miles in my SEL 115 DSG but so far I have had no problems what so ever. Really expecting that to continue.
Re: Brake clunk
Posted: Wed Jun 27, 2018 9:33 pm
by Polo+Pete
Thanks for the reply’s. My previous polo of 2014 had rear drums and I don’t recall a clunk. It would be good to hear of any new polo SE with drums and whether their owners experience the same, before I decide whether to return to dealer. Cheers
Re: Brake clunk
Posted: Thu Jun 28, 2018 7:05 am
by SRGTD
SRGTD wrote: Wed Jun 27, 2018 7:45 am It’s likely that a small movement of the brake pads in the brake calipers is the reason for the ‘clunk’ noise you’re hearing. I’ve read that it’s quite normal and shouldn’t be anything to worry about. My previous generation Polo used to do this when it was new; I’ve not noticed it doing it recently though.
Polo+Pete wrote: Wed Jun 27, 2018 9:33 pm Thanks for the reply’s. My previous polo of 2014 had rear drums and I don’t recall a clunk. It would be good to hear of any new polo SE with drums and whether their owners experience the same, before I decide whether to return to dealer. Cheers
Pretty certain it was my front brakes that used to make the clunking noise when I braked from reversing. My car doesn’t have rear drum brakes.
Re: Brake clunk
Posted: Fri Jun 29, 2018 10:54 pm
by kmm249
Hi!
Be gentle this my first post, I get a clunk noise with my brakes. I drive a SE 95 bhp. I only had the car over a week, done 300 miles so brakes are wearing in
My boyfriend who’s a mechanic has check it out as he want to make sure it was safe for me to drive. He saying that it the brake pads have got small amount of movement in calliper which is creating the noise. He’s saying it must be a design fault possible.
Re: Brake clunk
Posted: Sat Jun 30, 2018 11:25 am
by silverhairs
On most cars, when fitting disc pads, you put your bottom pin in and under the top pin is a thin spring steel plate to hold the pads down in position, in other cars it's like a shallow "W" shape.
If you have this clunking sound, which you shouldn't have, take it back.
Looking again at the posts it seems it's the rear drums, now the brake shoes are held between the hydraulic cylinder and a fixed peg, plus it should have a pin from the back plate through to the shoe with a spring before having a captive plate holding it all together, plus it should have an automatic adjuster to keep the shoes near the drum face. Really there's no way that they can move, this system has been with us for many years, so it's well and truly tested.
Unless VW in their wisdom have thought they could improve it and gone with something else? You cannot trust these Germans :lol:
Re: Brake clunk
Posted: Sat Jun 30, 2018 11:59 am
by RUM4MO
Or maybe down to the “new to Europeans” manufacturer of these smaller versions of the front brake calliper?
I can’t comment on which manufacturer currently supplies the rear drum brakes though.
Edit:- one thing wrt the rear disc brakes, the stainless metal clip on covers for the top and bottom pad<>calliper bracket points has been done away with! Every penny/cent counts nowadays as VW Group have some unexpected bills to pay!
Re: Brake clunk
Posted: Tue Aug 14, 2018 8:26 pm
by ryanpmay_1998
mine also does this when reversing. sounds awful when the windows are down. 1.0 95
Re: Brake clunk
Posted: Wed Aug 15, 2018 6:50 am
by Leif
I had an Up and after four or five years the rear drums brakes would definitely clunk when reversing. The last time, before I sold it, it had not moved for a week and they locked up, I had to rock back and forth for them to release. I have no idea if this is related but it was common on the Up.
Re: Brake clunk
Posted: Wed Aug 15, 2018 10:45 am
by RUM4MO
I think that "seizing on" if left parked for an extended period with handbrake on after driving in rain/wet roads is fairly normal for modern day rear drum brakes - unfortunately.
Re: Brake clunk
Posted: Mon Oct 01, 2018 7:09 pm
by p0l0man
My car does this, as well. Quite a loud "clunk" whilst reversing into drive and applying the brakes.
Has anyone taken their car back to the dealer with this? and what was the remedy?
Re: Brake clunk
Posted: Tue Oct 02, 2018 1:25 am
by wabbit1
p0l0man wrote: Mon Oct 01, 2018 7:09 pm My car does this, as well. Quite a loud "clunk" whilst reversing into drive and applying the brakes.
The OH’s Polo does this too. Gonna follow this thread and see what ideas/suggestions pop up 👍🏻
Re: Brake clunk
Posted: Mon Nov 19, 2018 7:31 pm
by Ramseyman
My 2016 Polo Match 1.2 TSI started doing this clunking noise a few months ago, took it in for a service and the senior technician I spoke to said it was normal for this model.
Surely this can't be right, must be disc pads not correct dimensions and over time they move about too much in the carrier. If I didn't know any better I would think that VW are trying to do as little warranty work as possible to make up financially for "diesel gate". I have problems with various noises from the engine as well and was told - normal for this model!
All very disappointing.
