how to remove dashboard please ?
Posted: Thu Jun 28, 2018 3:17 pm
by herones
Hello, I need remove dashboard on my volkswagen polo. How to remove the dashboard please?
Re: how to remove dashboard please ?
Posted: Wed Aug 22, 2018 10:43 pm
by JohnMcClaane
Remove carefully the steering wheel cover (leather one) which unclips together with the top part of the steering wheel cover. Be careful, the clips are not oo strong.
Adjust the wheel to the maximum pulled in position.
Unscrew the 2 screws that hold the instrument panel.
Pull gently from underneath to release the clip on top.
Undo the 2 connections at the back. Left is simple, just pull after pressing a tab. Right is a plastic lever pull.
Voila.
If you are referring to the whole dash - please see below
http://translate.google.com/translate?h ... powski.htm
Take your time and make sure to preserve clips and other fragile trim.
Good luck!
