6n1 - 6n2 compatibly
KlassMC
Drives: 6n1
Post by KlassMC »
Hi, I recently passed my test and was given a 1996 (p-reg) polo. I have made a few basic mods, but I am just wondering if other things from the 6n2 are interchangeable with the 6n1 ie gearbox/clutch/interior/etc if you could help or point me to any threads, I would appreciate it. Oh I forgot to mention the gearbox just went on it and wonder if I can use one from a 6n2 - I may just buy a 6n2 donor car and use gearbox, clutch and interior if poss so any help would be welcomed. Thanks
Re: 6n1 - 6n2 compatibly
6N and 6N2 engines have some silimarities but for the most part they are very different. Gearbox ratios aren’t the same and the 6N2 has a lot more engine management
A lot of the parts are interchangeable though. Seats can be swapped, steering wheel, even the entire dashboard and doorcards if you are feeling brave
KoryTem
Drives: Mk5 Polo GTI
Post by KoryTem »
It would certainly be cool if the engine was interchangeable too. They do have to sell new cars though. haha
JUUL
Drives: 6N 1995
Post by JUUL »
I know this is an old topic but I've just done a complete 6N2 upgrade on my 6N. So maybe someone will have some use for my reply. Do keep in mind that I've gone from a 1.4 60hp AEX to a 1.4 16v 75hp AHW...not all may apply to your particular application.
I've swapped:
- Engine and gearbox - straight fit.
- Axles - straight fit.
- Subframe - straight fit.
- Steering rack - straight fit.
- Gearbox mechanism - won't fit (unless you use 6N2 subframe).
- Exhaust - Only the middle and back box will fit (unless you use 6N2 subframe and engine).
- All wiring looms - some fitting required and majority of the connectors aren't the same.
- Dashboard - brackets on the side are higher than 6N. You'll need the 6N2 fuse box bracket as well.
- Heater unit - straight fit. (you'd have to use the 6N2 dash).
- Handbrake - straight fit.
- Floor carpet - straight fit.
- Seats and rear bench - straight fit.
- Safety belts - straight fit.
- Door cards - Lower handgrip screw won't fit and you'll need the 6N2 window strips, tweeter (first you'd have to remove a 6N bracket on the inside corner of the A-pillar). My car was a 3 door, the rear cards need to have a black plastic bracket removed at the bottom because the 6N one sits lower.
- Window mechanism - straight fit. If you are going for electric windows the connectors aren't the same.
- Windows - straight fit (for a 3 door).
- Ecu - straight fit.
- Interior filter - straight fit.
- Windscreen wiper mechanism - straight fit.
- Rear wiper mechanism - won't fit.
- Door locks - straight fit.
- Door handles - straight fit.
- Door seals/rubbers - need to be shortened, are a bit too long. They are a bit thinner as well, so be prepared for wind noise at higher speeds.
- Roof trim - straight fit but 6N2 trim on 6N will leave a small gap at the front of the car which might lead to leaking if not sorted.
I have a feeling I'm forgetting a lot more. But if you have any questions please ask :mrgreen:
L4certi
Drives: 6n
Post by L4certi »
Hi does the body work fit from an 6n2 to an 6n1 also to lower the car would I need a new subframe if so what one would an 6n2 subframe work
telbert twang
Drives: 1999 AER 1.0
Post by telbert twang »
JUUL - you have taken these cars quite down to atoms and perhaps you can guess - would that lock suit 1999 5D 6N1 tailgate for central locking ability project ( link below ) ? My car has manual locking cylinder and it looks mechanically impossible to rebuild it to work independently to get locked/unlocked either via key or central locking actuaotor - I need to find another lock version
P/N: 1J6827297 (G/C/D/K) - "Tailgate lock with 2x key for VW Golf IV 4 Lupo Seat"
https://www.ebay.com/itm/364184487709?m ... name=11051
JUUL
Drives: 6N 1995
Post by JUUL »
Hi Telbert, I'm not 100% sure if the Golf MK4 hatch lock module will fit a 6N1. By chance, I own both cars and I've fiddled with both modules. To be honest, they look exactly the same, but I've never tried swapping them. Why not try a 6N1 or 6N2 central locking module and fabricating some kind of bracket to make the electric lock work?
telbert twang
Thanks ! I also think they are the same - very similar in looks , but much more often the Golf model is designated than Polo, suitability wise (even the Seat models are more mentioned). Time to find out for 14 euros :D
The 6N uses its own version - 6N0 827 297M
